Results 1 to 13 of 13
Thread: Software Update
    NC
    Software Update
    Recently, I received a notice from BMW about a campaign to update the software on my 2015 R1200RT. I was told by the dealer that it is supposed to improve the shifting from 1->2 and 2->3. I do not have shift assist on my bike and wonder how the shifting, which I think is very clunky, can be improved. Does anyone know what this is about?
    Andy
    Andy
    2008 R1200RT
    Mar 2008
    Jax Fl / Atl Ga
    Software update -shift assist
    I had the update a couple of weeks ago. Using the assisted shift in lower gears was primitive at best before the update. A lot of jerks and bumps. It always worked well in 4-5-6 shifts. The update improved it a little, I still wouldn't use it in first and second but it works better in third-fourth shifts. You won't see any difference without shift assist pro.
    Ron
    Registered User JIGGIN's Avatar
    Oct 2007
    Lake Elmo, MN
    Sounds like the campaign update is for the shift-assist models. I already had mine.
    2014 R1200RT
    M20Ted
    Oct 2014
    New Jersey
    Software update
    Just got bike back from dealer for annual service and they did dme update campaign and replaced multi switch under warranty. Now, instead of digital speedometer when the sound is switched off I'm just getting the RT that used to just appear at start up. Is the digital speedometer function no longer available?
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    Quote Originally Posted by Tedjiggetts View Post
    Check the owner's manual - I am sure there is an option for that. The update probably set a bunch of options to the factory defaults.
    Yes, see the later item on the User Menu: Background. Choose Speedo as your option. Page 51 near the upper right corner.
    Ed
    2015 R1200RT; 2011 R1200RT RIP; 2000 Triumph 900 (sold)
    http://triumphantsblog.blogspot.ca/
    M20Ted
    Oct 2014
    New Jersey
    Software update
    Good thinking. I'll check it out.
    Mansfield,MA
    And welcome to the forum!
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    M20Ted
    Oct 2014
    New Jersey
    Software update
    Thanks for info and for the welcome. Worked like a charm!
    Seems like the update improved the shifting, but only got in a quick ride from the dealer, so not sure. Loved it anyway.! Thanks again.
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    I wish some of these features were explained a bit more in the manual. It is too easy to miss these things and almost impossible to find out what to do when things change.
    I am happy your problem has been fixed.
    Ed
    Interestingly I had the software update Friday and had that same exact issue. Eventually I figured it out. Make sure the radio is turned completely off. Then scroll to settings/user/display and set it to speedo.
    Quote Originally Posted by rockbottom View Post
    Ahh I see someone beat me to it. It's not specified in the manual. I mean the manual tells how to change settings but doesn't explain all the settings that can be changed.
    And I can't tell any different with the upgrade, but I don't have shift assist.
    Jun 2015
    Northeast Florida
    I recently had the software update done. I do not have shift assist and the update did seem to make the 1-2 and 2-3 shift much smoother, no clunk.
    2015 R1200RT Ebony
    Registered User Patgs's Avatar
    Feb 2016
    Mascouche, Qc
    Got the software update too, and improve shifting for sure! Dont have shift assist on my 15' GSA.
