Has anyone installed the booster plug on an 1150 RT?
And it looks like if I follow this correctly and if need be, I could run the zero = 250 on my 96 R1100RT.
Well, you clearly know more than me, all I know is that my bike runs great, doesn't surge and gets decent fuel mileage... better with pure gas.
Ian
Ian, What Roger says is without doubt true. I went the booster plug (homemade) route and took a week long trip of several thousand miles and found I had to do a TPS reset every couple of tankfuls to compensate for Motronic relearn. I finally through in the towel and installed an LC-1 with wideband O2 sensor and have never looked back. What Roger says about increased low end torque is spot on as well. The booster plug is not the proper way to address lean burning with these machines. If you like your bike's performance with the booster plug that's great but that's just not the best way to address the lean burn surging problem long term.
