Results 1 to 15 of 30
Thread: Can TPMS be retrofitted?
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    I have an 07 RT and I'm wondering if the TPMS can be retrofitted on it.
    If not, are there any good 3rd party solutions?
    Too bad I only have a ZUMO 350. There is a Garmin TPMS but it works with the 390 unit and not the 350.
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2019 R1250RT - 2007 R1200RT (186,000 km) - IBA # 56396
    Mansfield,MA
    I don't know about an OEM retrofit. I have a Tire Pressure Monitoring System for my motorhome. It uses a transponder that screws on in place of the valve stem cap. It reads pressure and temperature on a remote screen.
    I have found it works well and when the sensors have an issue, the company response was good.
    Mod Squad
    2009 F800GS 1994 TW200
    Liaison 20774's Avatar
    Was the TPMS an OEM system that was not installed? I mean can an owner opt in or out at time of purchase? From some past posts, it appears that there is an OEM system but it might take some reprogramming of the computer.
    I found some past threads about aftermarket products:
    http://forums.bmwmoa.org/showthread....-my-08-R1200RT
    http://forums.bmwmoa.org/showthread....essure-Monitor
    http://forums.bmwmoa.org/showthread....ssure-Monitors
    Dec 2013
    Laval, QC, Canada
    Thanks for the replies
    I found this system that looks interesting but I'm wondering how I could install it on my RT.
    It won't fit on the handlebars. I would like to find a way to put it on a Ram ball (My GPS mount can support 3 ram balls)
    http://www.ebay.com/itm/Steelmate-TP...dWKf1~&vxp=mtr
    Edit: I looked at it again and the kit comes with a 3M double sided sticker. It can be glued to a ram ball adaptor.
    Daniel
    Dec 2013
    Laval, QC, Canada
    I got my answer from the GS-911 Forum.
    I'm relaying it in case someone is interested
    You just need the module Anti-Theft-Alarm (DWA) with TPMS (RDK) 433MHZ part number 65758544716. ($256)
    Sensor rear wheel 36238521797 ($143)
    Sensor front wheel 36318532732 ($127)
    After mounting these parts you have to register RDC to the bike. Thats a dealers job.
    At last, I don't know the possibility of updating the Kombi (dashboard)
    Too expensive for my taste.
    I'll keep looking for an after market solution
    Daniel
    Dec 2013
    Laval, QC, Canada
    I ended up buying this one
    The handlebar holder doesn't fit on the RT but I intend to remove it and mount it on a ram ball next to my GPS (I have a Migsel GPS mount that can hold 3 Ram balls)
    Daniel
    Aug 2014
    Lakeland,FL
    Let us know how it works out. Looks very interesting and the price is right!
    Tourmeister gr8ridn2's Avatar
    Jun 2009
    Kern Valley CA
    Are the tire sensors small enough for clearance on horizontal valve stems such as those found on the S1000, r1200 series of motorcycles?
    Previous cap sensors would not clear forks and brake pieces due to their extended size.
    2018 R1200RT W - Continent traveler
    2016 S1000XR - Smile Maker
    1976 R90/6 - Just Plain Fun
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by gr8ridn2 View Post
    I don't know but if you go to this page, there a are pictures of the valve stems on a wheel, they compare them to another brand to show that theirs are smaller.
    I had ride-on smart caps on my RT and had no problem with the front wheel valve which is on the side. These look even smaller.
    Daniel
    Jul 2014
    Eastern Washington
    The one thing I like about the OEM system is also something I don't like about it.
    If pressure drops to whatever the system thinks might indicate a problem it illuminates the warning triangle on the dash. That's typically great as you hopefully learn about a potentially developing problem before handling suffers. When it is less than great is when the integrated batteries start to fail it will also illuminate the triangle. I had that happen during a trip and would reset it with my GS911 but it would come right back. My concern is that having the triangle on continually for a non real problem means that if another event occurs that might trigger the triangle it could be missed.
    Overall I like the OEM system. It's nice to be able to get an idea if pressures at high elevations on hot roads and such. If I didn't have it I think I would probably add something.
    Great Falls, MT
    Quote Originally Posted by jeffkruger View Post
    I also have the oem sys. How do you change out the batteries and what is the number for the batteries?
    Bernie
    Touring Rider GRLambert's Avatar
    Apr 2012
    Casa Grande, Arizona
    ... and how long do they typically last?
    Gary
    Casa Grande, AZ
    2016 R1200RT
    Sep 2006
    CENTEX USA
    The OEM replacement sensors run about $149 each, not designed to be serviceable. Have seen some live five years, others gone in two seasons.
    There are folks who have taken the unit apart and replaced the button battery, some have destroyed the plastic case trying.
    Old thread from adv site:
    http://advrider.com/index.php?thread...#post-27797181
    Steve Henson-Mod Team and past prez SABMWRA
    Dec 2013
    Laval, QC, Canada
    One more reason for me not to go OEM for the TPMS
    I'm not ready to spend over $300 every couple of years on new new modules because the batteries dies. (It's like buying $300 batteries)
    This is the complete list of material needed for a retrofit (Includes alarm system which is on the same module)
    Order from Endras Motorrad. (Canada)
    The items in your Order are:
    Quantity Product Stock Number Price EA
    1 Control unit for alarm system/RDC . 433MHZ65758544716 $346.68
    2 Remote control . 433 MHZ65752337407 $73.85
    1 Battery . 3V65752337504 $5.50
    4 Screw . M4X10,507147119858 $2.23
    1 RESISTOR . 120 OHM61137668405 $10.00
    1 Bracket, control unit65757729041 $18.00
    1 Sensor with valve . RDC36318532731 $185.00
    1 Sensor with valve . RDC36238521797$180.00
    Your order summary:8 products, 12 items $901.80
    Shipping To QC, Canada$ 0.00
    Total $ 901.80
    Daniel
    Spring Lake NJ, USA
    Quote Originally Posted by Dann View Post
    $10 for a 120 Ohm resistor? I'll sell them for $5 every day of the week (cost is about $0.10..)
