Page 1 of 4 1 2 3 ... LastLast
Results 1 to 15 of 46
Thread: Helmet speakers
    Helmet speakers
    I've a 2016 R1200RT and would like to be able to listen to the bikes radio through speakers in the helmet via the bike's bluetooth. I'm not interested in communication systems, but that seems to be all I am able to find. I thought this would be a simple add on, but perhaps it is more complicated than I realized. Any advice would be appreciated.
    Registered User BMARC153920's Avatar
    Dec 2014
    Orange County, NY
    A simple Sena SMH 5 or 10 will work. Pretty cheap and easy to install and you don't have to use the comm parts if you don't want.
    Sent from my KFSAWA using Tapatalk
    Registered Schmoozer irish's Avatar
    Oct 2009
    Madison, WI
    I just bought a Sena Bluetooth system this past year. I use it primarily to listen to music and podcasts from my iPhone via Bluetooth. I've only used the intercom once (I normally ride alone) and I have never used some of the features, such as the ability to have a Bluetooth enabled GPS pipe audio to the helmet.
    I think my experience is probably typical of lots of riders where you use some but not all of the features. There may be dedicated Bluetooth audio systems that are only for listening to music (I'm not sure on this) but for a little over $100 you can get a Sena SMH10 is similar product and just ignore the features that don't interest you. Easy to install and pair with other devices, audio is decent IMHO.
    14 R1200GS, 02 R1150RT (retired)
    Coming form a 60 yr old with tinnitus
    Although it might seem like a good idea now.....
    USE EXTREME CAUTION when contemplating adding more noise sources to your motorcycle experience.
    d'milan
    curmudgeon
    Dec 2014
    Orange County, NY
    Quote Originally Posted by dmilan View Post
    d'milan
    curmudgeon
    A lot of us use ear plugs even with helmet speakers to ensure the music is, much like the wind noise, at safe levels.
    Sent from my SD4930UR using Tapatalk
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    Quote Originally Posted by BMARC153920 View Post
    I use foam ear plugs any time I travel at highway speeds. I get navigation audio commands just fine even with ear plugs: just use enough volume.
    Harry
    I too use ear plugs now, (since the article in ON on hearing conservation foam earplugs, I'm guessing November, October issue maybe) with my Bluetooth speakers in my schuberth. Have no problem hearing audio. High frequency notes in music is muted a bit, but after a song or too it's not noticed. What I do notice now is not wearing my ear plugs... Out of control loud now.
    that coming from a 48 year old with tinnitus.
    R. Reece Mullins Ebony R1200RT (Gretchen)
    MOA # 143779
    MOA Charter Club #5 #364 #100
    BMW MOA Vice President
    MOA # 143779
    Registered User rocketmanli's Avatar
    Feb 2007
    Bay Shore, NY
    When I used my Garmin StreetPilot 2720 (until recently) I had J&M hard-wired helmet speakers in my Shoei Multitech, and heard everything clear as a bell while wearing foam earplugs. Now that I updated to a Zumo 660, the helmet speaker volume was horrendously low. Even with all the volumes set at 100%, I could barely hear it. I just purchased a set of SPlug earbuds from www.Plugup.com, which serve as speakers and earplugs (so I now removed the helmet speakers & no longer need the foam plugs) and with the GPS volume set at 40-50% its perfect. Can't say why the audio-out volume is so much worse on a newer, more expensive GPS unit, but it is what it is.
    2009 R1200RT, 2005 R1200C Montauk (The elusive Piedmont Red & Silver "350" commemorative model); and 2002 R1200C Montana
    Moderator of www.Chromeheads.org
    wanderer
    Jun 2009
    Bridport Vermont
    Is blasting music thru foam ear plugs a good idea??
    I too have hearing loss from a youthful love of loud two stroke dirt bike, too much chain saw use, shooting etc.
    Now I always use foam ear plugs. And NO high volume music pumped in.
    I have tried expensive custom made ear plug audio, speakers in helmets etc. While they all worked, it still seemed to me that they were to loud to get clarity above background wind noise.!
    After all any speaker has to over come by a considerable amount the wind and other background noise to be heard. Music especially needs to substantially above (15 / 20 db) above the background noise to allow tonal appreciation.
    I'm no audiologist (maybe some one on this blog is) but it seems to me that wind noise is 70-80db (maybe higher) levels in my helmet. Then you put in foam ear plug which attenuate 25db...so the noise is in the 45-55 db range. Still pretty loud! Then you add in your music which need to be 20db higher to be heard. This means 90 to 100db outside the ear plug...clearly dangerous levels here. But evan at the ear it is 65-75 db in the ear. Loud! Loud enough to further ear damage if sustained for lone periods? I think so but do not know for sure.
    These db levels i mention are crude estimates form a db meter app on my I phone so should not be considered precise....but I do think they are near the mark.
    Does this make sense?
    Aug 2014
    Lakeland,FL
    I like these for many of the reasons pointed out in this thread.
    NoNoise Earplugs
    wanderer
    Jun 2009
    Bridport Vermont
    Quote Originally Posted by mikegalbicka View Post
    NoNoise Earplugs
    I don't like them.
    I bought them at the NYC motorcycle show a couple of years ago. The ceramic tube is supposed to be tuned to "motorcycle" noise. Which is wide band noise.
    I took them out and used them once. The wind noise was clearly LOUDER than my foam ear plug.
    Never used them since.
    Note in their advertisement. They identify noise sources but DO NOT SAY what their attenuation is. Typical marketing double talk.
    Sorry but my opinion.
    I suspect their tuned wave guide might work well in narrow band applications...not motorcycle.
    Aug 2014
    Lakeland,FL
    Quote Originally Posted by bobzeliff View Post
    I don't like them.
    Sorry, I forgot to include YMMV in my post but it is always implied. I do agree that the wind noise is louder than with foam plugs. However I am not sure that means it is less safe. They do provide some Protection/attenuation data at the bottom of this link but probably not enough detail for sure. If you know of some independent testing data that proves their claims are bogus I would be all ears!
    Mar 2011
    socal
    Quote Originally Posted by carguyjason View Post
    Jason
    Go with the BMW comm system, you paid for the wonderwheel on your RT why not use it
    By doing so if you later want to communicate it won't be necessary to buy another unit
    Jim
    wanderer
    Jun 2009
    Bridport Vermont
    Well said! I don't have any data on my foam plugs either...just the subjective "quieter"
