Results 1 to 15 of 22
Thread: '15 RT battery tender options
    Love living and riding! aholgate's Avatar
    Mar 2012
    NH
    Cool '15 RT battery tender options
    Good morning all and Merry Christmas.
    Question, I looked but didn't find anything list in the FAQ so I thought I'd post. I bought a new RT in July and I don't know if I can use one of my old BMW battery tenders on it?
    Can someone she'd some light on some options as I have three bikes and I don't want to purchase yet another type of tender. I used a combination of two BMW tenders and an old brick tender from Sears (works the balls).
    Thank you,
    Ashley Holgate
    1994 R1100RSA Pearl White (sold)
    1995 R1100RSL Cobalt Blue (own)
    1996 #326 R1100RT Glacier Green - buy it before you can ride it (sold)
    2002 R1150 RT Silver (own)
    2015 R1200RT Ebony (own)
    Registered User glenb's Avatar
    Nov 2013
    Fort Erie, Ont., Canada
    I don't know it this helps but this is what I use for both my F700GS and my wife's 2015 R1200RT;
    Shown with the F700GS
    Purchased from our dealer. It is expensive, but works great and is convenient.
    Dealer suggested sharing one between the two bikes due to the cost and switch it from one bike to the other on garbage day (so you remember to do it each week). I really like our dealer
    Niagara BMW Riders #298
    2013 F700GS (his), 2015 R1200RT (her's)
    Aug 2015
    Ventura County, CA
    I bought a battery tender to learn that the can-bus system on the new bikes, i.e. 14-15 RT, needs a compatable charger unit. The can-bus compatable charger can plug directly into the BMW accessory plug outlet to monitor and charge the battery. Alternatively, the Battery Tenders can mount their cable onto the battery and the cable can hang out the side seat to access.
    I wanted a cleaner solution, and to use the accesory outlet, so I returned the Battery Tender and purchased a Tecmate Optimate 4 BMW version-Model 245 from my local BMW dealer who sold them. Working great so far!
    '14 R1200RT
    If you run a separate pigtail directly to the battery you may continue to use the chargers you have.
    Mar 2011
    socal
    I wired a powerlet plug directly to battery, with fuse, this buy passes canbus completely. Optimate charger with BMW plug, as a added benefit heated gear plugs in without causing faults
    Registered User JIGGIN's Avatar
    Oct 2007
    Lake Elmo, MN
    Quote Originally Posted by landis View Post
    I bought a Tec Mate 4 that is supposed to be Can Bus compatable, followed directions to switch it to Can Bus, switched ignition on, plugged it in and all its doing is flashing the # 6 & 7nlights which I understand means it's ready for Can Bus. Switch off after about 15 seconds and light continue flashing (forever). Never seems to go into the 30 on 30 off cycle. Now I do have this "Can Opener" installed with Clearwater lights and the "Billie", could this have some effect? Not ready to peel covers and hook directly to the battery, yet. Would like the convenience of the plug-in.
    2014 R1200RT
    Registered User RYD1WD's Avatar
    Sep 2014
    Charlotte, NC
    At my previous dealership, as part of the PDI process and at no charge, we swapped the primary power outlet with a 15 AMP powerlet socket wired directly to the battery. At my current shop, we install a 20 AMP Gerbings lead directly to the battery - you can get a coax to SEA adapter that allows use of most chargers, compact air compressors, etc... there are several ways around the CanBus, directly to the battery that give you diverse functionality. Fielders choice
    Greg North - Sales & Marketing Manager, BMW Motorcycles Of Charlotte
    There are motorcycle owners, and there are motorcycle riders.
    And then there are those of us for whom motorcycling is an essential part of our journey - a way of life, and looking at it.
    Mar 2012
    NH
    Thumbs up
    That's to all that responded. I like the additional information on wiring an outlet with fuse to the battery to run equipment that bypasses the Canbus so I can run my equipment that causes issues such h as my compressor and heated vest.
    Since we're getting snow this week I guess it's a springtime project!
    wanderer
    Jun 2009
    Bridport Vermont
    +1 Once you have this SAE pig tail, you can use it for heated clothing and most importantly a electric tire pump which pulls way more current that CAN buss will allow.
    Registered User ROBERTSI's Avatar
    Feb 2013
    Espanola, Ontario, Canada
    yep
    Quote Originally Posted by bobzeliff View Post
    I have done exactly that.
    Sep 2014
    Charlotte, NC
    Yes, but be aware the typical SEA pigtail like what you get with/for the battery tender lead isn't designed for the AMP capacity needed for heated gear. Battery tenders generally require 1.5-5 AMP depending on the model. If heated gear is part of what you want to use, start with the Gerbings 20 AMP capable pigtail direct from the battery and use a SEA adapter from the coax connection to facilitate the other devices.
    Sep 2014
    Charlotte, NC
    Slime pulls 6.2 AMPs, the newer bikes will allow 10 through the CanBus.
    Heated gear is still the biggest user.
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    Quote Originally Posted by RYD1WD View Post
    My 2015 R1200GS has a battery cover with only screw. Take off that screw and cover and you have the negative terminal and an added positive terminal to its right. These allow jump starting of the bike if the battery is low. But it also allows an easy hook up of my old battery tender with alligator clips. And I could hook up the air pump that way.
    I use only a heated vest, and it has worked through the CanBus by way of the accessory socket.
    Harry
    May 2013
    PEI Canada
    I have a powerlet cable plugged into a SAE pigtail I use for the tire pump etc. Works just fine with my Tourmaster Synergy jacket. SAE pigtails usually have fairly hefty wires; just make sure the fuse is appropriately sized and that will blow before you have any problems. You guys just worry too much. I use a regular 6/2 amp charger through the pigtail and disconnect when the green light shows it's dropped to trickle charge. Once a month is fine, never had a problem.
    Mansfield,MA
    Yep, I do some wiring-
    Direct to the battery is best IMO.
    Mod Squad
    2009 F800GS 1994 TW200
