rangerdog
I've read about these failures and most of what I've seen either applies to do-it-yourself repairs or simply complaining.
Now that BMW is warrantying fuel strips for 12 years, the DIY approach is not something I'm considering. Mine went out (or I think it did) shortly after I bought my 2009 R1200RT and I've got an appointment with my dealership next week to get it fixed.
I do have a question: Since the warranty only applies to the fuel strip, I want to be pretty sure that's what failed. I'd like to know what the symptoms are, including any I might not have seen.
Here is what I experienced:
With a very near full tank, my fuel gauge went to zero and the warning light came on.
This continued for several days without change.
Then upon one restart, the warning light was off and the fuel gauge went to full even though I'd ridden about 140 miles on that tank. It continues to show full 40-50 miles later after multiple restarts.
The miles to empty is obviously wrong, showing zero when the fuel gauge showed empty and now tells me I can go 280 miles on less than half a tank.
Meanwhile, the mpg readout continues to give me numbers that are at least quite believable.
Is this typical of fuel strip failure? I just don't want to get to the dealership and learn my fuel strip is fine, but something else probably more expensive failed.
It seems likely this question is answered elsewhere, but at this point it's buried beneath thousands of posts that don't answer it.
Thanks.
Thanks.
