Results 1 to 6 of 6
Thread: battery removal on 2015 R1200 GSA (LC)
    Hey everyone, I'm not familiar with the layout of the forums….how can I access pictures and instructions on how to remove the battery on a 2015 R1200GSA? Specifically, I've got the rubber strap undone and am trying to "Pull mounting plate on position 1 outward and remove it upward" as per page 137 of my owner's manual. I'm trying to access the battery posts so that I can connect a battery wiring harness to power a Gerbing's heated jacket liner. Thanks! --Andy
    Registered User BMARC153920's Avatar
    Dec 2014
    Orange County, NY
    There is a power post to the right of the battery for this use, no need to remove the battery at all.
    Do you mean the accessory socket up by the handlebars?
    Dec 2014
    Orange County, NY
    Quote Originally Posted by 109561 View Post
    No by the battery to the right there is a small post with a big red wire going to it. That is a positive hook up point for unswitched power access without needing to touch the battery.
    never mind. I got it. The plate has to be lifted 1/8", then pulled outward, then upward more. Thanks anyway!
    Dec 2014
    Orange County, NY
    You should still be using the power post, that's what's it for and the battery is a tight fit already before adding more wires.
