Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Do the Service Techs at most shops warm the bike before draining the fluids?
    Registered User wvpc's Avatar
    Dec 2009
    Ypsilanti, Michigan
    I was in the process of doing a 36K mile service on my Camhead when a thought occurred to me. Conventional Wisdom calls for the bike oils to be warmed by riding for several miles before draining. OK. Yes the oil does drain faster and any suspended matter should flow out.
    Then I started to think how do the Sevice Techs at dealers worldwide drain bike oils? I can't recall ever seeing any techs warming bikes prior to service. Has anybody else?
    12 R1200 RT
    83 R100 RT
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Sure. I've seen them warm a bike at idle, sometimes on a lift with the bike connected to an exhaust hose.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    After riding 2.4 hours to get my bike to the shop, it's usually pretty warm when they pull it. This Saturday though, I'll have em do the throttle body synch and valve adjustment, buy the oil and filter and do it myself when I get home, for no other reason other than I love servicing the oil on my bike.
    But to answer your question, yes, a good service department will change the oil hot or warm.
    Dec 2009
    Ypsilanti, Michigan
    Ok but that would not warm the transmission or final drive.
    12 R1200 RT
    83 R100 RT
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Quote Originally Posted by wvpc View Post
    When on the centerstand, BMWs since the 80's K and Oilhead typically rest on the front tire, so those models could be idled in gear. It wouldn't warm the gearbox and rear drive much, but would get those oils stirred up.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Spring Lake NJ, USA
    Quote Originally Posted by rangerreece View Post
    They're adjusting the valves with hot heads? That's a specific no-no for BMWs.. too much expansion of different metal components (and they don't give a hot-valve-clearance value..)
    Registered User David13's Avatar
    Nov 2011
    Utah
    To me, thinking the oil must be warm to drain out is akin to believing a battery will discharge if placed on a concrete floor.
    Old wives tale, somehow adopted by some motorcycle guys.
    You are not dealing with molasses there, nor old crystallized honey.
    The preposterously different amount of oil you might, and I say might get out is so minuscule as to make it not worth my while. On any vehicle.
    Unless it was running molasses.
    dc
    Jul 2007
    dc, do you run cane or sugar beet molasses when you do run molasses in your Beemer?
    Kevin Huddy
    Mar 2004
    Alexandria, VA
    Agreed, unless they change the oil after doing the valves.
    Jim
    Mar 2004
    Alexandria, VA
    Quote Originally Posted by David13 View Post
    dc
    It isn't the amount of oil that you are trying to influence, it is the contaminants IN the oil. If you warm up the motor, trans and FD, the contaminants are suspended in the oil and flow out more readily when draining it.
    Jim
    Santa Cruz CA
    Yes. you'd get more contaminants out.
    But see Don's email, above - the valve clearances wouldn't be correct if the valves and heads were hot when adjusted.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Mar 2004
    Alexandria, VA
    Quote Originally Posted by jimvonbaden View Post
    Jim
    Quote Originally Posted by dbrick View Post
    Jim
    Sorry for the confusing post. No they do the valves cold. This weekend I'm having the switches on the right handlebar replaced... cosmetic. While there I'll get the throttle body since and valve adjustment. The techs at Pensacola simply time the list of services I usually show up with to be conducive to a warm or cold engine. When I show up with fluid changes, which is rare as I usually do it myself, they do at first to take advantage of the warmth of fluids.
    Life is not always perfection. And life has compromises.
    Yes, best shop practice is to drain lubricants hot. Yes, valves really need to be adjusted cold. Yes, good customer service would not require keeping the bike over night or a few hours to cool.
    The ideal is to ride the bike (to the dealer shop or DIY shop), drain the lubricants as soon as cool enough not to cause injury, then allow an hour or two to cool down and then adjust the valves.
    In my mind the crucial thing with the lubricants is to get them stirred up. This will allow most if not nearly all of the crud to be swept away with the draining.
    Apr 2006
    dc
    What D13 said. If you have so much particulate matter in your oil that it will settle out overnight, you have some serious issues. As far as it draining more, BS! After the bike sits several hours, gravity has returned most of the oil to the pan. Start the bike and it is spread all over the inside of cases, pistons, cams, valves etc, and will take hours to return to the crankcase. I think the tradition is carried over from when straight 30, 40 and 50 weight oil was the norm, and if it was cold, the stuff was like honey.
    I actually try to park my vehicles overnight before draining.
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
