r90 turn signal
rayma60927
my turn signal housing that slides onto the end of the chrome shaft sometimes rotates downward and I cant see any way to tighten it up no set screws etc. any ideas. thanks
Have you removed the lens? Is there something on the inside that can be tightened?
Hi
Hi. There are two small screws that holds the blinker housing on to the chrome shaft via a little metal saddle. Check the screws first for tension , PO hasn't been ripped the thread out of the housing ?.Make sure that nothing is out of shape for the saddle to preload the chrome shaft to hold it into position.
Hopefully the picture attached. See if this helps. I believe there is actually a "lock" position when everything is working properly. I think I ran an independent ground when I put this back together so that I wasn't relying on the frame, etc.
