roger 04 rt
Roger,
No stock in MCN's measurements, or no stock in anyone's dyno results? Is MCN doing something different with the dyno compared to other reviewers?
-D
Good question, I was referring to dyno measurements used to calculate actual horsepower.
If the inertial dyno operator is very careful to add an eddy current load so that there is a cruising load (meaning a load before the throttle is cranked open), confirms that the bike is cruising in Closed Loop as shown by an AFR reading, measures AFR ahead of the catalytic converter, and has insured that all Long Term Trim values are stable (meaning that the bike has been ridden for several tanks of fuel without any modifications, then I would have comfort in the results as an indicator that could be used for tuning but still don't think it could be relied on as actual top HP.
Look at the AFR plots for many dyno runs. They start at AFRs of 18-22:1, how exactly is the engine running at those AFRs? The answer is that the dyno wheel forced the engine into overrun fuel cutoff after decelerating from the previous run and dried up the TB and intake of its usual wetted-wall fuel. This results in sluggish initial acceleration.
Because the nature of an inertial dyno test--no initial load usually, inertial resistance of the wheel about 50% of road resistance, and because of the limited duration of the test--I wouldn't use one as an indicator of engine horsepower which is measured on a different type of dyno.
Interestingly, a GS-911 set in high speed logging mode can be used to measure acceleration, from that you can calculate torque and horsepower if you've previously measured the bike's Cd and frontal area. Then several runs can be made on a level road and averaged. And on-road acceleration and top speed is what we're after.
