Gearing and tire size and issues like that do NOT impact HP/Torque measurements any more that motor cycle weight,etc.
Temperature / humidity/ altitude do effect engine performance but most dynos have various type of compensation to address these normal variables
All this goes to competent Dyno testing. Maybe the state of dyno technology only give 10% accuracy?? That is what I would like to know. Are dyno test figure any more value that Manufacture's press statement? I have believed that dyno numbers were more valid. I now question that.
Transmission ratios changing an engines horsepower production? And flywheels weights are all the same now I do believe. I'd agree these varying results are based more on testing equipment, testing conditions and bike's "set up".
The RS uses a lighter flywheel, this was in the article.
Does the watercooled boxer have a flywheel?
To enhance rideability, especially on off-road terrain, the drive’s flywheel mass has been increased by 2.1 lbs. and an extra vibration damper has been incorporated into the powertrain.[/B]"[/I]
That's interesting, I thought it was the crank that had the added weight.
I looked at the parts fiche and could not spot a flywheel.
I think the total "flywheel" mass is provided by multiple parts that spin with the crank, mainly that large gear at the front (not listed separately in the fiche) and the alternator.
I would actually like to hear more about those u-joints. I just did 7 on my Jeep......Would have bought some of those- if I thought they existedMust have, because BMW's press materials for the introduction of the new GS Adventure for MY 2014 touted the 2.1 lb heavier flywheel. See paragraph extracted from press materials below:
For the first time on a BMW production motorcycle, the maintenance-free cardan-shaft drive is now positioned on the left-hand side.
MCN recently did an extensive article justifying using electronically collected data extrapolated from various means
Is that another way of saying they Googled the information
Look at the Winter 2015 issue of BMW Motorcycle Magazine. Maybe the oil level of the three bikes differed!
So my 2 cents is that I wouldn't put any stock in the MCN measurements.
