View Poll Results: Do you fill your bike well it is positioned on the side stand, or center stand?
Voters
88. You may not vote on this poll
  • Center stand
    35 39.77%
  • Side stand
    53 60.23%
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Thread: Did you fill up your RT or GS positioned on the side stand or the center stand?
    Cowboyatheart
    Feb 2009
    Pender Harbour, B.C.
    I have a 2008 RT, and I normally fill up by putting my motorcycle on the center stand. While doing that today, I was wondering whether or not I would get more gas and if it was on the side or the center stand. How do you feel up yours?
    Moringa, your body & brain will thank you! PM for discounts Smart Mix at TasteMoringa.com
    XM3 Energy, real energy for the body & brain, no sugar high, XM3.Energy
    Cowboyatheart
    Feb 2009
    Quote Originally Posted by nelliott View Post
    Can't fix spelling on polling question, I bet you "feel" your bike in all positions, so go with the intent, "feel = fill", in this case
    Liaison 20774's Avatar
    nelliot -
    I was able to get into the poll and edit the title. HTH!
    atlanta
    To answer your question, filling on the center stand allows a bit more fuel into the tank.
    Marty Hill
    7 GS white
    Ride till you can't
    Registered User rocketmanli's Avatar
    Feb 2007
    Bay Shore, NY
    Side stand for me and my '09RT. Then peek inside to make sure its filled to just under the bottom edge of the red plastic tube. That's full for me, otherwise pump clicks off at less than a full tank.
    Sep 2006
    CENTEX USA
    What centerstand...on three bikes, there is no choice for us
    Since my riding companion is on a 5 gallon bike , I use sidestand on GSA, was same on the RT. Rare day to put any on a centerstand for us. Do try to get max fuel in some situations west of the Big Muddy as fuel opportunities sometimes are far apart for the 5 gallon bikes range if not topped off.
    Jul 2013
    Solvang, CA
    Quote Originally Posted by martyhill View Post
    i drilled a couple of 1/4" holes about 1/2" from the top of the red neck thingy on the right hand side....no need to put the bike on the centerstand to get a "full" full...
    ~wyman~
    If you want to know the volume difference there are two approaches. One is to fill it on the sidestand and then put it on the centerstand and see how much more fuel can be added. This is the preferred method.
    The other is to fill it on the centerstand and then put it on the sidestand after failing to properly close the cap. This allows you to see how much gas spills out, but is not the preferred method.
    Some of us have probably tried both methods.
    Albuquerque, NM
    Centerstands are for maintenance only.
    Correcting an empty gas tank situation is maintenance.
    Kent Christensen
    21482
    Peter D dunc723's Avatar
    Aug 2012
    Nashville, TN
    I've done both, but it's hard to imagine the difference is enough to make a difference, unless like henzilla said you're in a place where you really have to maximize the range.
    I tried this, but I had a terrible time collecting it to measure the difference.
    Pete
    Pete
    When life throws you a curve, lean into it. (Seen on a t-shirt at MotoGP Indy)
    '06 R1200RT, '12 F650GS, '04 K1200GT (Sold)
    Dec 2011
    Menlo Park, CA
    FWIW: Formerly when I was on a long ride ('09 RT) I'd fill way up into the neck (the "red neck thingy" as Wyman so eloquently described it) to try to get myself a bit of a cushion until the next fill. I found that I could get about another half gallon or so into the tank after the pump clicked off.
    Recently I've just been filling up to the bottom of the neck, not up into the neck. I've noticed that the fuel sensor strip seems to behave more consistently with this approach. Before the fuel gauge would often indicate anywhere from 250 miles range at full to 350 miles range at full when I filled into the neck. It often got partway there and held, not accounting for fuel burned. Since I've been filling only to the bottom of the neck it seems to have stabilized right about 320 miles at full and counts down in accordance with miles traveled. This seems to be pretty close to theoretical true - 7.1 gal x 46 mpg = 327 miles. But that means that 0 miles means empty, not 0 miles means the start of the one gallon reserve.
    Regardless, after four failed fuel strips, I still fill by miles ridden per the trip meter, not by what the fuel gauge says. I typically fill at about 260-270 miles into the tank, and put around 6 gallons in. Again, consistent with ~320 miles range on a full tank.
    And I do it on the centerstand, partially because I have to pull the tank bag off, and if I do it on the side stand and put the tank bag on the saddle, the tank bag falls onto the ground.
    JayJay
    '09 R1200 RT, '73 R75/5 Toaster (under rehabilitation)
    Lots of rice burners in the past ...
    Registered User AHD43's Avatar
    Jul 2014
    Central, PA
    Side...
    Mansfield,MA
    I find I can get a little more in when the bike is upright on the centerstand. I don't bother and actually watch out for a "filled to the brim" condition unless I was headed back on the road. An "over-fill/max-fill on a hot day can foul up the venting system.
    YMMV
    Mod Squad
    2009 F800GS 1994 TW200
    Nov 2014
    Central PA
    Neither. I don't get off of the bike when gassing up. Is this odd? I see guys on cruisers off their bikes all the time, but I figured that was so they could polish the chrome if they see a smudge.
    2010 BMW R1200RT
    2008 Suzuki vStrom DL650 (sold)
    Mansfield,MA
    Quote Originally Posted by jebersole View Post
    Depends
    Mod Squad
