Riding in the mountains a few nights ago both of my low beams went out, luckily I have low mounted lights on the forks and the high beam did keep working. The following day I removed the left hand bulb, put an OHM meter on it and it was fine so I put it back in place and it started working again. I was going to take out the right hand bulb but just couldn't get my hand into that small of a space.
I took the bike into the Asheville shop, they changed the right hand bulb that was blown and both work fine now. The mechanic thought when the right hand bulb blew the computer assumed it was a fault with that circuit and shut down the left bulb as well. He also said that cycling the switch a few times, which I did, told the computer to turn the circuit back on. Has anyone else experienced this and also some idea of how to change the right hand bulb would be a big help.
Thanks,
Mo
Thanks,
Mo
