rangerreece
RangerReece
Dude, your my hero!
Dude, your my hero!
Nice bike, looks great. Take your time getting used to it, don't get a case of the "new bike speedies".
Friedle
How did your carb resynch go? I would certainly do that...plus you might need to think about either changing the needle position to one step richer (this is a coarse change and will result in lower gas mileage) or maybe try a slightly bigger main jet.
Trying to sort out an annoying problem when in 4th or 5th gear at 4-5k RPM has lack of power and a slight bucking. Once past the 5k rpm it pulls strong and smooth. Replaced the things I had not when doing the rebuild. New plug wires and and floats and needles. Sad to say it has not helped
Sounds like you're running okay once you get to the main jet. Do you have the needles set to the right notch? If set too low you'll run lean until the needle is fully lifted and then you'll have switched fueling to the main jet.
The attached drawing is the top portion of a carb needle. It regulates the flow of gas through the needle jet. If you have the needle set at position 1 - closest to the top - the needle will be inserted into the jet more than if it was in other positions. Since the needle is deeper into the jet it is restricting the flow of gas MORE, making it run leaner. If you put the needle into position 2, 3 etc. each higher position raises the needle so it's relative position in the jet is higher and it restricts gas flow LESS, making it run richer.
When you twist the throttle you end up raising the needle. By putting the starting point of the needle into the "richer" or higher numbered positions you are effectively raising the needle a little bit.
Probably worth checking snobum's website for recommended needle position for your configuration. I "think" it's second slot. I've got the Bing book out in the shop and can check for you tomorrow. What #'s are on your carb bodies?
I'll read through the snowbum again.
The numbers are 64/32/201
Much appreciated. Thank you!!!
Pretty sure you have a typo there on the third # - should be two different third numbers left/right side and it will be like:
64/32/9 & 64/32/10 or 64/32/11 & 64/32/12
I'll check my book though for 201 as they might have jumped up for the /7's?
