Results 1 to 13 of 13
Thread: Road Tar??
    Jan 2015
    Libertyville, IL
    Unhappy Road Tar??
    Yesterday got into road construction and the dreaded "Fresh Oil" area with no way out. It appeared the oil was not to fresh but upon getting home I notice both tires had a build up of tar/oil with small stones sticking to them. Sooo now what does anyone have a good method for removing the stuff from the tires or do I just ride and try to wear the stuff off and hope one of the stone don't work their way into the tires and cause a flat? I hate road construction!!
    Registered User BMARC153920's Avatar
    Dec 2014
    Orange County, NY
    Kerosene will remove it and not harm any finishes, but TIRES?? Just ride it and it will wear off.
    Canada and the Alps
    If any is on the motorcycle (not the tires), I use WD-40 which I finally found a use for.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Hot soapy water with an abrasive scrubby to get off the worst build-up, then ride it.
    Kevin Huddy
    Silver City, Montana
    MOA# 24,790 Ambassador
    Tourmeister gr8ridn2's Avatar
    Jun 2009
    Kern Valley CA
    Smile
    Quote Originally Posted by GlobalRider View Post
    Like this, I use WD40 from a gallon can. Moisten a rag (using gloves) and lightly rub the oil and tar bumps off the painted finish. You don't want to rub hard as it will scratch the finish. Let the WD soften and melt the tar away. After it is removed I give the bike a good wash with car wash soap. This will remove the residue left by the process. I had a real mess of tar and oil on my bike after returning from Billings. The wheels and paralever arm required several applications of WD before the spots and bumps were removed. It now looks like new, smooth to the touch.
    2018 R1200RT W - Continent traveler
    2016 S1000XR - Smile Maker
    1976 R90/6 - Just Plain Fun
    Registered User hdtrader's Avatar
    Mar 2015
    Three miles from BMW of Huntsville AL
    I did the same and had tar all over my tires several months ago. I used a plastic bondo/putty knife and washed it real good...then I just rode the rest of it off. I'm a bit skeptical about using WD40 on the tires...
    Randy
    North Alabama
    2015 R1200RT
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by hdtrader View Post
    Gee, I can't imagine why.
    Jun 2009
    Kern Valley CA
    Clearly, WD40 on the tires isn't a great idea. For the tires just riding on them has cleared the tar in a few miles.
    Registered User dbaliko's Avatar
    Jun 2010
    Flower Mound, TX
    I use 3M automobile adhesive remover. It works like a charm.
    Doug
    Doug
    '12 R1200RT - The Green Machine
    '07 R1200RT - (sold)
    Registered User AHD43's Avatar
    Jul 2014
    Central, PA
    My favorite is a home made solution of Kerosene, Dawn dish soap and water mixed in a spray bottle
    M
    I've found elbow grease applied in generous proportions evenly distributed over affected surface works well.
    Sep 2006
    CENTEX USA
    I guess I am real glad my GSA has black rims, black frame and misses most of the tar it seems.
    Steve Henson-Mod Team and past prez SABMWRA
    Quote Originally Posted by AHD43 View Post
    M
    Yeah, works great for me too.
