Results 1 to 15 of 25
Thread: 2015 R12GSA water pumps
    Has anyone had a problem with the water pump on their 2014-2015 R 12 GS or GSA? I have a 2015 GSA that is in the shop for the 6K service. The dealer advised me that my water pump was leaking and that it needed replaced. Upon asking a few questions the dealer advised that I was lucky to have made it to 6K miles because they have replaced several of the water pumps at the 600 mile service. Is there a problem with BMW water cooled boxer cooling systems?
    Registered User Paladinwest's Avatar
    Jun 2010
    BC South Central Interior
    No problem with the cooling system, just the water pump seal. Change the pump under warranty. Generally fixes the problem although some people have had the replacement dribble as well. In 5000 kms while I waited for the new pump to arrive the coolant leakage was only noticeable by the stains on the side of the engine near the weep hole, the coolant tank showed no discernible level drop. New pump has been leak free all summer and 12,000 kms.
    2014 R1200GSA 38,000, 2008 HP2 Sport 11,000, 2008 R1200GSA 100,000 (Sold), 1990 R100GSPD 102,000, 1986 K100RS 154,000
    Registered User donmoe's Avatar
    Dec 2014
    Jupiter, Florida
    I recently returned home from a long summer tour from Florida to Alaska on my 2015 R1200GSA, which now has nearly 28k miles behind it. At one of the four regular service visits, the service manager mentioned the weep hole, showed me where it is, and recommended that I check it regularly since other bikes were reportedly having water pump seal leaks. Thus far I haven't yet noticed any leakage at all.
    During the tour, the bike was flawless, except for the saddle, which I replaced with a Bill Mayer saddle at 8,500 miles. I've been quite satisfied with the new saddle.
    Don
    2015 BMW R1200GSA.......2008 Kaw Concours 14......1974 Kaw Z1
    2013 Triumph Trophy SE....2004 BWM R1150RT..........1973 Kaw H1
    2010 Kaw Concours 14......1981 Kaw KZ1000
    Jan 2015
    NE Pennslvania 80/81
    Quote Originally Posted by 146023 View Post
    Same here! Lol, but never went back to get a replacement pump,,, have ridden 11,800 miles so far, and not a major issue. Just keep your eye on the coolant level, it does spit out the side hole near tranny case.
    I guess It will get done at my 12,000.
    Chuck Berry cberry's Avatar
    Indian Harbour Beach, FL
    I've now got 22K smiles on my 2015 GSA wethead. There was a very slight weep shortly after I bought it, which I attribute to 'wear-in' for new equipment. None since. No other problems, other than replacenent of the cruise control switch et al , and issues with the lock cylinders on the OEM bags. I'm happy riding on Tourance Next's which seem to last only a month or so.
    Chuck Berry
    2013 R1200RT Anniversary Edition, 2015 R1200GSA (retired), 2009 G650GS,
    MOA #94523, IBA #27506 National Parks GOLD (still OLDEST at 69 in 2007) and again in 2016 at 78, SS1K at 76 & 77, Lighthouse GOLD Extreme at 77
    I'm thinking that I have a coolant leak. 2015 G S A I've had for 2 weeks with 1900 miles on it. Not happy
    Sep 2014
    Chicago & The Driftless Area
    weep hole?
    Quote Originally Posted by donmoe View Post
    Don
    So where is this Weep Hole?
    There is a hole (circled in red) in the case that I presume is the weep hole. It appears to be where something is coming from on my bike. It is on the left side of the motor.
    I'd suggest that you clean up the current mess and then monitor the area for continued leakage for a while. Your mess looks more excessive than my 'wear-in' leak was.
    Chuck Berry
    I have not had any weeping on my 2014 RT. I do wonder why the hole was put there. Was some discharge expected and if it is, is it ''normal''?
    Buck in Greensboro, NC
    2013 R 1200 RT Midnight Blue - traded, 2014 R 1200 RT Ebony Metallic, 2016 S 1000 XR
    I think that I've been told on other bikes that the weep hole is there so you can tell if the water pump is starting to leak. You can catch it before it gets to bad.....
    Imported Norwegian Viking viking59's Avatar
    Oct 2015
    South Carolina
    I got a leak on my 15 R12 GSA. I'll watch it for a while before I "call it in". It's mostly when the outside temp is low.
    2015 Gelände-Straße Abenteuer Wassergekühlt Urban Angriffsfahrzeug
    “Don’t Let The Fear Of What Could Happen Make Nothing Happen.”
    vegas bmr guy vegasbeemerguy's Avatar
    Aug 2005
    Las Vegas, Nevada
    Coolant leaks Water cooled BMW engines
    The issue is a seal that allows coolant to leak from the left side of the engine case through the "Weap hole." I purchased a 2014 R1200RTW in Feb. of 2014. I had issues w/ the water pump, considerable coolant dribbling from the weap hole by the first service.
    The second pump seal failed at @ 20K.
    I now have just over 37 K on the Rt- on the third water pump. FYI- this was also an issue w/ the early GT and GTL water cooled engines.
    I suspect the vendor has replace or modified the seal on the water pump since the bikes were first manufactured, if they haven't already in current batch of pumps being supplied to dealers?
    Interestingly, I also purchased a R1200GSA ( 2014 ) in Aug. of 2014. Approaching 18 k w/ no sign of coolant leaking from the weap Hole.
    Definitely a warranty issue and is replaced often by dealers. Hoping a newer water pump seal will solve this issue?
    Have fun and ride safe,
    Steve
    Steve
    Jun 2010
    Was just showing someone where the weep hole was and noticed that I now have a small leak from the new water pump (that was replaced about 15,000 kms and 6 months ago). I guess the replacement pump will need to be replaced. The new leak must have just started as it is leaking much less than the original and it wasn't there two weeks ago.
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    I noticed a leak on my ride to Billings. The dealer in Sturgis was willing to replace the water pump, but did not have one in stock.
    I kept an eye on the coolant level. Back in New York, I talked to my dealer. He said they sometimes weep a little, and not to worry about it, so I won't. He said under certain circumstances it might weep a bit, and that was the advice from BMWNA.
    I've never seen any leak on the ground and the coolant level has not changed enough to worry about it. I haven't seen the level go down at all.
    Harry
    My fleet: 2015 R1200GS, 2017 Toyota Prius Prime (plug-in hybrid)
