Results 1 to 15 of 17
Thread: 2001 R1100S 2 second knock/noise at start-up
    Sep 2015
    Duluth, MN and Minneapolis, MN
    Is it 'normal' to have a couple of seconds of knock/noise when engine first starts? I honestly don't know if it's always been there and I'm just now hearing, or if it's something new… thanks for any comments
    Very common defect but not "normal". Bad left-side cam chain tensioner. There is an upgrade available. See Rubber Chicken Racing Garage web site for more information.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Ufda happens..........
    Feb 2005
    Trinity, NC
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Sep 2006
    CENTEX USA
    Welcometo the forum iselin
    Think the fellas pointed you in the correct direction...post a pic of that S at the top of Oilheads, it drives the RS guys
    Left Coast Rider
    Nov 2011
    And justifiably so!
    Mar 2010
    Vancouver, B.C. Canada
    Quote Originally Posted by iselin View Post
    The left side tensioner that came with your bike has been superceded by a new one which is identical to the part used on the R1200 engines. In the old ones the oil leaks out when the engine stops. The new one retains the oil so there is no "knocking" on startup. The sound you hear is actually the cam chain slapping since it is loose until the old tensioner fills with oil and starts pushing on the chain like it's supposed to. The original tensioner causes premature wear of the cam chain and guide. Not good!
    Any BMW dealer will have this part available as well as Tom Cutter at the Rubber Chicken Racing Garage.
    Sep 2015
    Thanks so much for this information…I'll give it a try
    Sep 2015
    Thanks to all for the input…I'll give the new left side tensioner a try
    Really appreciate the input, I think I'll give the new left side tensioner a try
    Left Coast Rider
    Nov 2011
    Having posted the same question myself about 4 years ago, odds are 10 to 1 that this is the problem.
    Don't forget to report back. And don't forget to post a picture of your S!
    Aspiring Profligate Jeff488's Avatar
    Apr 2007
    Nacogdoches, TX
    Here's Tom's site.
    He's a good asset to our band of bikers.
    http://rubberchickenracinggarage.com/chain.html
    '08 BMW R1200RT
    '08 Suzuki DL650 "Screaming Yellow Zonker"
    Looking for Ed Sanders' Truck Stop.
    Albuquerque, NM
    You identify if you already have the upgraded tensioner by noting the size of the hex nut welded to the tensioner. 17 mm = the original, 15 mm = the upgraded version.
    That said, I've had an upgraded version completely frozen in place, i.e. unable to adjust any tension. And, I still have the startup knocking. Have replaced right side tensioner as well. Still investigating.
    Kent Christensen
    21482
    Mar 2010
    Saw this happen once before on a friends 1200RT which has the same new tensioners. A very minor scoring of the inner piston was found to be the cause upon disassembly. The mechanic at Ozzies felt that this was a manufacturing defect. He figured with all the oil in there it certainly did not happen due to lack of lubrication.
    Left Coast Rider
    Nov 2011
    Was he using synthetic?
    Feb 2008
    New style tensioner
    If it is frozen in place (not compressing) it has been used before and is full of oil.
    You must depress the little ball inside and pump the oil out before re-installing.
