Easy way to change the sightglass, read it here somewhere, it is a 1 on the difficulty list, use a soldering iron, melt the plastic right through, use a cotter pin puller and it pops right out.
Past the time to replace! It is very brittle at this point.
A 3 on the difficulty scale if you feel like tackling it.
BTW...welcome to the Forum
dieselyoda;1013228 said:9/10 times.
Then there is the 10th one which is corroded in.......no so easy.
9/10 times.
I used a particular brand of synthetic oil in my Oilhead and my Brick/Bricklet and it stained the sightglass to black in one season
