Results 1 to 5 of 5
Thread: Seat Lock Stuck
    Seat Lock Stuck
    I just purchased a 2015 r1200gs Adventure (love it so far). Today I removed the seats to adjust the rider position, then locked both seats back down. However, the key is stuck in the seat lock and I cannot get it out. Any suggestions?
    Registered User BMARC153920's Avatar
    Dec 2014
    Orange County, NY
    Not sure about the gs but on my rt it's possible to turn the key too far and or not enough and it won't come out until centered and there doesn't seem to be a noticeable detent to know when you are there. Try moving the key slowly to the right while pulling gently to see if you can remove it.
    Mansfield,MA
    Quote Originally Posted by andyroto View Post
    Welcome to the forum!
    Sometimes the manual will have a procedure explaining things.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Seat Lock Stuck
    Thanks for that thought. Just tried it to no avail. Key does not seem to be able to make the full rotation either (can only turn it partially). Both seats are firmly in place, just cannot turn fully or remove the key.
    Mansfield,MA
    Try sitting on the seat and turning the key. It could be the newness of the seat and rubber components that has things under tension.
    I have also seen someone leave a tool under a seat and forgetting that was why the seat was so hard to lock.
    Mod Squad
