Results 1 to 6 of 6
Thread: Dellorto Carb Help
    Dellorto Carb Help
    Anyone got a tip for installing the throttle cable through the slide return spring and getting the little square end ferule into place on a 38mm Delorto carb for an R90S? Seems like two hands are not enough. I made 4 attempts yesterday and couldn't get it. Made 4 more today and thought I had it but the square cable end did not seem to be properly seated. I poked at it with a small screw driver and it didn't move, so I thought I had it. But, the cable came out as I was inserting the slide into the carb body. I am thinking of making a simple spring compressor from a piece of all thread, then tie the coils down with 3 small wire ties. Any other ideas?
    Liaison 20774's Avatar
    I've never been that close to a Dell'Orto before. Snowbum talks about them here...didn't see anything specific...maybe there are other links on the page:
    http://bmwmotorcycletech.info/dell.htm
    There are some past posts in the Similar Threads pane at the bottom of the page...see if there's any help there.
    Oct 2015
    SO CAL
    My recollection is the ferrule should be an oval not square, where did the cable come from? The spring is stupidly robust, someone makes a slightly less springy spring but its been a while since I did it but I think the trick is thumb on the lid two fingers on the slide, squeeze and use you're other hand to guide the ferrule into its spot but if its a little big you might have to take a file and shape it a little. Dellorto cables for a BMW are one of those parts that are getting harder to find, I think I had to have Flanders in Pasadena make them for me and I seem to remember they still weren't quite right.
    There's this website:
    http://www.herdan.com/dellorto/
    Somewhere on this website is some Dell'Orto info:
    http://www.bevelheaven.com/
    I got the job done this afternoon. Took about 3 attempts. In Trial 1, the cable ended up sandwiched the slide bottom and the C-clip. This does not give you straight line pull from the seating hole. In Trial 2, I had to quit, as my fingers were at their limit of endurance. Got it on Trial 3. Must have been due to being experienced by then. Only glitch was that the spring was cocked at the bottom due to slide slip of the last few coils. Grabbed the spring and pulled it while I jiggled it a bit until it slipped into place. Then had to monkey around with getting the slide into the carb body and getting the accelerator lever properly position. That took may 3 tries. The cable was a genuine BMW part. I will take a look at the Ducati links later. Probably some good stuff there.
    Sounds like the factory recommended procedure to me. Or at least similar to the way I did it.
    '61 Clubman's Gold Star, '13 690 Duke, '13 Daytona 675R, '14 Street Triple R, '17 1290 GT (gone but not forgotten: '76 R75/6, '84 R100, '76 R90S)
  1. Dellorto issue - 75 R90S
    By berniematic in forum Airheads
    Last Post: 03-03-2016, 07:38 PM
  2. Dellorto problems
    By ccolwell in forum Airheads
    Last Post: 10-09-2013, 11:20 AM
  3. Jetting Dellorto PHF 32 for 1984 R65
    By jtatknox in forum Airheads
    Last Post: 09-12-2012, 02:03 PM
  4. Conversion to Dellorto
    By Rubytuesday in forum Airheads
    Last Post: 06-07-2009, 07:36 AM
  5. Dellorto Carbs
    By varkr90s in forum Airheads
    Last Post: 07-04-2006, 01:39 PM
