Results 1 to 6 of 6
Thread: Headlight bulb
    Headlight bulb
    I don't want to go the HID route. Any suggestion for a whiter than stock long lasting bulb? Seems all the ones I find have a short projected life.
    Buck in Greensboro, NC
    2013 R 1200 RT Midnight Blue - traded, 2014 R 1200 RT Ebony Metallic, 2016 S 1000 XR
    Registered User Paladinwest's Avatar
    Jun 2010
    BC South Central Interior
    Osram H7 Rallye, they are 65 watts 2100 Lumens as opposed to 1400 and in my experience have much better life than the standard H7. I was changing my H7's about one per year and my first Rallye lasted 2 years. You can find them here http://store.candlepower.com/osraulhiouh7.html or sometimes on Ebay. You may have to be careful on Ebay as I understand that they are sometimes not as advertised.
    2020 R1250GSA 1000 2014 R1200GSA 80,000 (traded), 2008 HP2 Sport 11,000, 2008 R1200GSA 100,000 (Sold), 1990 R100GSPD 102,000, 1986 K100RS 154,000
    Quote Originally Posted by Paladinwest View Post
    Those sound pretty nice. Have you used them with the new R1200RT's and is our bikes power output/electrical system good to go for the increased power draw?? Thanks
    Registered User rocketmanli's Avatar
    Feb 2007
    Bay Shore, NY
    I have 3 of them in my '09RT and they work fine. Can't speak for newer models.
    Jun 2010
    I used them on my 2008 GSA with no problems for nearly 50,000 kms and on my HP2 Sport for about 5000 kms. I split an order of ten with a friend who put them in his 2013 GSA last year so he probably has 25,000 kms on his with no problems as well. I was changing the standard bulbs about every 12,000 to 16,000 kms. Can't speak for my new GSA as it has an LED headlight so I am not using the Rallye's in that bike. I know that some people have had trouble with the plastic bulb socket getting brittle from the heat even with the standard bulb but I have not seen that problem on any of my bikes. I think as long as the contact between the bulb and the socket is clean and tight you should be okay. If there is a bad contact there it could get worse very quickly as the poor connection will generate heat which will make the connection worse. I did buy some ceramic sockets from Candlepower just in case but I never had to install them. YMMV.
    Nov 2009
    AL/FL Gulf Coast
    They are the best available lumens/lifespan, but DON'T expect them to be HID white or you'll be very disappointed.
