Hi folks,
I'm getting ready to do my first brake fluid change on my new to me 2004 R1150RT, and wanted to use the opportunity to upgrade the line to some Spiegler SS lines.
I have searched through various threads and You Tube video's on line and think I have a handle on it except for one thing (which is probably a dumb question)...
Since I am replacing the lines, do I need to bleed out all fluid including that from the ABS control unit prior to taking the old lines off? Most of the info that I have found on line really talks to the bleeding process where you are drawing in new fluid while bleeding out the old to minimize any introduction of air into the system. Since my lines will be removed, should I just resign myself to the fact that I will have a bunch of air one the system that I will have to contend with when drawing in the new fluid?
Any thoughts would be appreciated!
Plock
Plock
