Results 1 to 8 of 8
Thread: Finding replacement parts/bolts
    Question Finding replacement parts/bolts
    Hey everyone I am new to the forum. I was recently replacing the tire on my R1200CLC and when I went to put the tire back on and torque down the brake caliper mounting bolts one of the bolts started to break. I was able to save myself from having to drill the bolt out but I can't seem to find replacement bolts anywhere online. I guess my question is.. what is the best place to find replacement bolts/parts? Thank you in advance for any help.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    From the BMW Parts fiche
    34 11 7 713 338 ISA SCREW - M8X32-10.9 ZNS3 $2.67
    Ufda happens..........
    Thank you
    I appreciate it. I guess I just wasn't entering the right thing on Google.
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    Instead of Google, check out the on-line parts fiche from Max BMW -
    http://www.maxbmw.com/ is their home page, click on "Parts" (just below the MW of the header), click on "Fiche" on the page that comes up, select your model and year, then select the category.
    A&S has a similar setup - http://www.ascycles.com/ then click on "Resources", then "Illustrated Parts Catalog".
    Quote Originally Posted by folterung View Post
    Google is unlikely to drill down to specific vehicle parts.
    A call to a dealer will. And as described above, on Max', A&S' and Real OEM you can even look up parts and numbers.
    Registered User froggy's Avatar
    Feb 2010
    Ballwin.MO
    If you use Max, you get m&m s with your shipment. Who can turn that down?
    We drove all this way for a DEAD END ! My son!!!
    02 Silver RT1150 My 1st BMW Bike ...Totaled 2/23/16
    13 Black R1200RT 90th Annv
    Craig
    Note the "10.9" in the bolt description. This is a metric designation of a higher strength bolt, similar to ASA Grade 8. Not a run of the mill Ace or True Value bolt.
    If you know what you want Fastenal or mcmaster.com have it. If you liked to wander through the hardware store when you were a kid visit mcmaster, it's amazing.
