Results 1 to 8 of 8
Thread: 2015 GSA - Handle bar risers
    Old Rider - OK Mechanic 105258's Avatar
    Mar 2004
    Teulon Manitoba Canada
    Anyone found a set that can be installed with the existing brake line and cables ?
    David Nicholls
    Teulon Manitoba - Canada
    2015 R1200GSA-LC
    Mar 2005
    San Tan Valley, Az
    I installed a set from TouraTech with no problems. ROX has risers also, but some lines need to be relocated.
    bob
    neanderssance man sedanman's Avatar
    Jul 2011
    Pawling NY
    I put Rox risers on my wife's R1200GS and rerouted the cables/hoses without disconnecting any of them.
    Paul
    Stop wrestling with your motorcycle, dance with it.
    2011 R1200RT Traded
    2014 R1200RT fully optioned
    Aug 2011
    mashpee, Ma
    Touratech 25mm bar risers part #045-5256 I installed on my 2014 GSA with no adjustment of cables or lines. Made me a happy guy.
    Janda
    2014 GSA
    2011 R1200R [sold]
    Rox Risers also makes a set that does not require rerouting of cables, etc. I bought these from Revzilla "Rox 1 1/2" Block Risers BMW R1200GS Watercooled 2013-2015" and paid $85.50 for them. They are not the traditional Rox Risers that rotate forward / backward but, are the basic block risers. I put a set on my '15 GS and am very pleased with mine! Good luck!
    Mar 2004
    Cable re-routing
    Quote Originally Posted by sedanman View Post
    Did you have to re-route both the throttle and brake lines. The brake line is pretty easy to re-route but how about the throttle wires. do they disconnect from the throttle assembly .. Can you give me some idea of what I am looking at.
    Thanks for your reply.
    David Nicholls
    2015 R1200GSA-LC
    Jul 2011
    Pawling NY
    I put the bike on the centerstand and removed the cap on the top of each fork tube. There is a nut that secures the fork to the top "triple tree". Remove one nut at a time and lower the fork leg out of the way to reroute the cables. Secure the side you started with before moving to the other side. This sounds scary but in fact is very easy with simple tools. Total install time was 45 minutes.
    Paul
    2011 R1200RT Traded
    So far I've tried the Wunderlich 40mm (raises and brings bars back), 25mm (straight block risers) which do not require re-routing of any lines.
    Also tried the Rox 2-inch adjustable risers, which do require moving the lines outside the fork tubes as described above. The Rox site has pretty simple instructions on how to do this. Very easy to do.
    I didn't care for the way the Rox risers mount, so I settled on the 25mm Wunderlich risers as my riser of choice on my 2015 GSA.
