Results 1 to 15 of 16
Thread: '14 R1200RT Cold First Starting Problems
    Mar 2015
    San Francisco, CA
    I have a '14 RT purchased in November 2014 and I now have 7.2k miles. When starting it cold, it will turn over and over and then (usually) start on the second attempt. It has done this for about a month now. When it's warm, it will start up every time as the day it was new. Today, it wouldn't start at all and turned over and over without firing. The 6k service has been performed. I'm taking it into the dealership for warranty work on Tuesday, but I'm not sure I can get it to start.
    Anyone else have this problem? If so, what was the fix?
    PS: apologies if this has already been covered. these forums still baffle me...
    Mar 2015
    San Francisco, CA
    Video of Cold Start Problem
    this was after several attempts, but here is a video of the starting issue: https://youtu.be/9ySX84qagoA
    Sep 2010
    Glen Burnie, MD
    Torrnado,
    I've had my 2014 about 16 months now +-6K miles. Just this season (which started for me early March after the snow cleared out) I started having a "Similar problem" in that the RT no longer likes to start on the first try when cold. However, it almost always starts on the 2nd crank. My 05 Rt was ALWAYS like this. Maybe starting closer to the 3rd crank.
    I'm sorry there is no solution from me, but wanted to let you know that I've noticed a change after the first storage season.
    I'm due for annual service (did the oil already, but whatever else is left) and plan on asking the question about this. I'll report back if I get any info from them.
    Registered User BMARC153920's Avatar
    Dec 2014
    Orange County, NY
    Mine does it and so does a buddies gs. We did some testing and we found if you turn the key on and immediately hit the start button the bikes fire right up first try. However if you wait more than a few seconds and or let all the gauges reset and then try it almost always takes two tries to start the bike.
    We haven't found out why but our theory is something is losing its value or resetting when you allow the bike computer to fully cycle. That something is corrected or set in the second start attempt.
    The fact that we can repeat the one or two start procedure 100 percent of the time on two different bikes confirms it is a bug or issue but exactly what we don't know.
    I have a gs911 but haven't yet tried starting with it connected nor checked for codes.
    Aug 2014
    Lakeland,FL
    Does cracking the throttle just a bit help or not in these tests?
    Dec 2014
    Orange County, NY
    Quote Originally Posted by mikegalbicka View Post
    Hmm never tried that.
    Aug 2014
    Lakeland,FL
    Quote Originally Posted by BMARC153920 View Post
    Makes a difference on my 07RT as does a fresh battery of course.
    Registered User wbrownell9's Avatar
    Jun 2013
    New Castle, DE
    Thumbs up
    That video was alarming - seems it never did start. Mine cranks without firing the first time, then starts right up the 2nd time. Occasionally it'll start the first time, but not like when it was new, where I think it turned over maybe two revolutions before starting. This behavior started sometime after the 6K service. I asked the dealer to look at it on the 12K but nothing was wrong (of course). I thought I was supposed to wait for the boot sequence to finish before starting, but will try to start in the middle and see what happens. Warm it starts no problem. I'll ask again at the 18K service next week.
    2016 R1200 GSA
    Maybe, no-start on first try is a hidden benefit.
    Sometimes I purposely let go of the starter button before my LC boxers fire up. I let it crank for a moment or 2 and then quickly abort.
    Cranking first, then releasing the starter button, then firing them up in earnest seems to relieve the horrible rattle that these engines exhibit for a second or so upon start-up.
    Don't know what the rattle is, decompression device or cam chain , or so I've heard tell. Whatever it is, sure doesn't sound much like the high end precision machinery that I was hoping for.
    Reminds me of a moment in time with my long departed 2002 R1150RT, before I replaced the defective cam-chain tensioner. A friend requested that I start up my newly acquired BMW so he could marvel at it's glory(tongue in cheek). He listened to it start, laughed, and jokingly asked if it was a diesel.
    Embarrassing really.
    d'Milan
    Jun 2015
    Northeast Florida
    Since the new RT's have a slightly higher compression maybe they need a compression release valve (CRV) if they don't already. A few years back I had my Harley motor built up (96" to 103" and with higher compression) and ended up with a starting issue like this, killed batteries every 6 mo. The newer HD's with the 103" stock motors now have automatic compression release valves.
    2015 R1200RT Ebony
    Quote Originally Posted by ehc0720 View Post
    Oh, they have one alright... maybe one in each head, not sure about that.
    That may be the cruddy rattle and slap you hear at start up.
    https://www.youtube.com/watch?v=GfAg2w4dXjQ
    Mar 2015
    San Francisco, CA
    not in my case...
    Mar 2015
    San Francisco, CA
    thanks
    thanks everyone for all the replies. i took it into BMW of San Francisco today and will report back what they find. without offending anyone here (and in a slightly irritated tone), i didn't pay $24000 for a bike that won't start anytime i want it to. my honda ran like a swiss watch and never hesitated to start (ever), so i'm none too pleased with this issue. i'm hoping it's just a simple fix or software update because i don't want to fight BMWofNA to get my bike working like it did when it was new. i always let the computer and dash cycle fully before starting as someone once told me that it's best. i hadn't tried to start it cold without letting this happen.
    thanks again everyone...
    Mar 2015
    San Francisco, CA
    Quote Originally Posted by torrnado View Post
    BMWofSF reports that after they checked fault codes (none present), reset mixture preparation adaptation values, it started without hesitation. i found it interesting that they performed the work first and then attempted to start it. at the end of the day, the bike seems to start as expected.
    let's hope this is the end of the problem.
    May 2015
    Denver, North Carolina
    My 2009 Dyna Super Glide is not a high-compression machine, but I used to have issues getting it to turn over in the summer sometimes. I had the stock cams replaced with S&S Easy-Start cams which have a build-in compression release function. After that the motor spins over with ease. My R1200R LC has a 12.5:1 compression ration. I wondered if the motor has compression releases installed or not. It does spin over easily though.
    Pete
    Pete
    2015 R1200R
