Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: Brake Failure warning
  1. #16
    DrPaul DrPaul's Avatar
    Apr 2007
    Bartlesville, OK
    Quote Originally Posted by wezul View Post
    DrPaul - 2008 K1200GT, 1973 R75/5
    2004 R1150RT - sold,1974 R90/6 - sold
    2002 R1150RT - sold,1987 K75S - sold
  2. #17
    Blocking the slow lane
    Edwardsville, IL
    Module Masters in Idaho just repaired the unit on my 08 GT with the same symptoms.....identical 24048 and 24049 codes and a steady Brake Failure light.
    Got the unit back last week, screwed the lines back in and bled the system, and still have the Brake Failure light!!
    GS-911 offers a ton of tests that you can do to the ABS unit, and my bike's modulator seems to respond just fine. Except when I actually take it out on the road.
    Debating whether or not to replace the sensor wires.......$119 apiece.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
  3. #18
    Apr 2007
    Bartlesville, OK
    Quote Originally Posted by jdiaz View Post
    Did you clear the fault codes?
  4. #19
    Cage Rattler wezul's Avatar
    Nov 2006
    Glen Ellyn, IL
    Curious how others are fairing with this. Sorry perhaps I am not following protocol
    Hey Diaz when did you move South?
  5. #20
    Edwardsville, IL
    Quote Originally Posted by DrPaul View Post
    I thought I did. But after 25 miles, the bike seems to have fixed them for me. I put 500 miles on last Sunday riding over to MotoGP without an issue.
    Bruce, we moved in May of 2014. I took a new job outside of St Louis.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
  6. #21
    Apr 2007
    Bartlesville, OK
    Looks like problem solved! I should get my ABS module back from Idaho Thursday. Leaving early next Saturday on 4,000 mile trip so hope the install is uneventful.
  7. #22
    Edwardsville, IL
    Re-bleeding the lines was a bit of a pain.....buy the quart can of brake fluid instead of a pint.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
  8. #23
    Apr 2007
    Bartlesville, OK
    I bought a GS-911 to confirm that the ABS module was indeed the cause of my Brake Failure warning. I see it has a brake bleed test function. Did you use the device in the refilling and bleeding process?
  9. #24
    Edwardsville, IL
    I didn't. Just used my manual bleeder.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
  10. #25
    Spring Lake NJ, USA
    You can trigger the same function (activating the ABS pump) with a simple trick.. turn the ignition on, spin the rear wheel, gently press the rear brake pedal down. You'll hear and feel the pump. This gets any trapped air out of the ABS pump.
    BTW - say hi to Sue for me!
  11. #26
    Edwardsville, IL
    Why didn't you fix my bike when you visited? Thanks Don.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
  12. #27
    Apr 2007
    Bartlesville, OK
    ABS module failure - all is well!
    Just to close this thread, Module Master got my ABS unit back to me a couple of days before leaving on a 4,000 mile trip out to Glacier NP and back. Install, brake fluid refill and bleed went smoothly. Absolutely no problems with brakes on trip. Fortunately, I didn't need to test the ABS function! I'm very happy with the service from MM and highly recommend them for this repair. With shipping and all, the job cost me ~ $600 but half of that was the price of the GS-911 (which wasn't essential but I've wanted one forever and this gave me the excuse I needed to buy one!). That pales in comparison to the nearly $3K it would have cost going to BMW. Another recent experience was replacing the Xenon headlamp; BMW wanted around $285 just for the part and the EXACT Philips lamp from Amazon was $65. I'm certainly not anti-dealer; I want mine to stay in business. But with pricing differences that dramatic I will continue to look to the aftermarket especially when recommended by my MOA brethren. Thanks to all who posted advice!
