Results 1 to 15 of 27
Thread: Brake Failure warning
    DrPaul DrPaul's Avatar
    Apr 2007
    Bartlesville, OK
    2008 K1200GT with 32,500 miles. Brake Failure warning light came on (steady, not flashing) yesterday riding home from work. No recent work done that might affect wheel ABS sensors. Last brake service was one year ago - flushed both front and rear systems, pads renewed. Brakes seem to work normally, no strange noises, etc. I'm suspecting ABS module failure unless someone on the forum has other thoughts. Anything I should do before taking bike in for dealer diagnostics? Thanks.
    DrPaul - 2008 K1200GT, 1973 R75/5
    2004 R1150RT - sold,1974 R90/6 - sold
    2002 R1150RT - sold,1987 K75S - sold
    Registered User lazygoodan's Avatar
    Jul 2003
    MI
    Brake failure warning
    I have the same exact issue. 2008 K1200GT, 30,500 miles. Light came on solid. GS911 shows the following (I hope this attachment works):
    I believe it must be some type of electrical issue where there is no power to the ABS module. I tried to clear the fault code, but no dice.
    Unlike DrPaul, I did just have 3 recalls completed at my dealer. Since that service work, I've had two rear brake lights go bad and this ABS fault in less than 200 miles of riding (seems odd).
    Thanks for any insight.
    Jim
    2008 K1200GT
    Apr 2007
    Bartlesville, OK
    Quote Originally Posted by lazygoodan View Post
    Hmmm. Actually, I did have the bike in to the dealer three weeks ago for the rear wheel flange recall. I'm sure there is no connection ...
    Cage Rattler wezul's Avatar
    Nov 2006
    Glen Ellyn, IL
    Suspect it is the ABS modulator, if it is I am sorry.
    Is expensive. You have rebuild options, can't recall but think the place is in Iowa.
    http://forums.bmwmoa.org/showthread....t=#post1002845
    Apr 2007
    Bartlesville, OK
    Quote Originally Posted by wezul View Post
    Yea, you're probably right. It is very interesting that others have experienced this failure shortly after the rear wheel flange replacement. I haven't carefully inspected the rear end yet but plan to do so this evening. I suspect I've ridden ~ 100 miles between the flange service and the fault so probably unrelated unless there is some wire chaffing, etc. As I recall, the ABS unit rebuild company is Module Master in Idaho. I hear they do good work for not a lot of $$ and extend a 5 year warranty. Does anyone know if I still have integrated (linked) braking action with the module failure? Thanks.
    Jul 2003
    MI
    DrPaul,
    It is my understanding that 2008 K1200GT's do NOT have linked brakes. That's one of the reasons I bought a 2008 instead of the 2007 model.
    Jim
    2008 K1200GT
    Jul 2004
    Charlottesville, VA
    The fault codes above are for the motor brush fault. It's not that expensive to deal with. Send the unit to ModuleMaster in Idaho. I think the last ones I had done were maybe $2xx.
    OP: you need to get the fault codes read.
    Anton Largiader 72724
    Tech articles - YouTube
    Apr 2007
    Bartlesville, OK
    Many thanks, Anton. I'm moving in that direction. Other than no ABS, is there any risks riding the bike until the repair is done?
    Calgary
    DrPaul,
    They do have the linked brakes, but not the servo assisted brakes. Same reason I chose to buy an 08 and not an earlier model.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2019 F850GSA
    Apr 2007
    Bartlesville, OK
    Quote Originally Posted by mcmxcivrs View Post
    That's what I remembered as well. Thanks.
    Jul 2004
    Charlottesville, VA
    Quote Originally Posted by DrPaul View Post
    Do you know there's no ABS? Try to skid the rear in a parking lot.
    Could it be the pad wear indicator?
    Apr 2007
    Bartlesville, OK
    I have not actually tested the ABS function but that is a good idea. Pads front and rear were replaced less than a year ago. I'm not getting the pad wear indicator light on the display but will visually inspect them and check the connections. Thanks for your help.
    Nov 2006
    Glen Ellyn, IL
    I still own a 2008 K1200GT.
    The ABS modules of this era are prone to failure. Mine failed @ 8,00 miles. Can't tell ya how many I've seen in local shops with the l/s fairing off, waiting for their module to be returned by Module Masters.
    Also,
    The brakes on K1200GTs and K1300GTs are only partially linked.
    Using the handle bar brake lever will give you front and rear linked.
    If you use the rear brake foot pedal, you get rear brake only.
    d'milan
    Apr 2007
    Bartlesville, OK
    Quote Originally Posted by dmilan View Post
    d'milan
    That is correct .
    Went out this afternoon and tested the ABS function by locking the rear brake on the lawn several times and there was complete lock-up; no apparent ABS function at all. So, I'm guessing I have a module failure. Is there a need to verify with reading the fault codes before removing the module and shipping off to Module Master? My dealer can't get me in for over a week to read the fault codes. Order a GS-911 and DIY (I've wanted an excuse to buy one of these for a long time!)? I've got a 4K trip planned in 4 weeks. All advice appreciated!
