Results 1 to 3 of 3
Thread: oil pressure switch 92 R100RS
    Go Leafs Go CANADIANSTEVE's Avatar
    Nov 2004
    Voluntown CT
    Hi all
    Do I remove the air line in order to make room for the socket and ratchet ... will I end up needing to bleed air from somewhere or just tighten back up after changing the switch ?
    steve now in CT
    moved from Toronto
    92 R100RS
    MonoRT MonoRT's Avatar
    Jun 2011
    Huntington Beach, CA
    My 85R80RT has all of the same plumbing and the fairing. I used a deep 24mm thinwall socket with a universal joint to remove that oil pressure switch the first time it started drooling.
    When I was a kid, I loved to look at the Craftsman tools in the Sears catalogue and I would see the crowfoot wrench sets and I would ask myself "what are those good for?". They're also OK for getting that dang oil pressure switch off. However, a 24mm open end crowfoot might be harder to find than the correct socket.
    Fenwick, Ontario Canada
    Quote Originally Posted by CANADIANSTEVE View Post
    Hi all
    Use a deep socket, no need to bleed anything. Make sure you have a new crush washer.
    Ambassador Emeritus BMW MOA Ontario Canada
    Niagara Riders
    Knights of the Roundel #333
    1977 R100RS, (Retired) 1993 R100GS
