Results 1 to 15 of 25
Thread: 2V - Valve Shim Thickness - Printed vs. Actual (95 K75S)
    Jun 2009
    Rochester, MN
    I recently acquired about 20 valve shims for my '95 K75S and I'd like to get rid of the ones that I can no longer use.
    Out of all of them, I only have one that still has the printing left on the backside. That particular one reads 2.50, but I measure it at 2.55 mm with my digital calipers. Therefore, can I assume that all of the other other valve shims are actually +0.05mm above what they would be printed at?
    Hopefully that makes sense...
    I wouldn't try to generalize. You may be measuring a manufacturing tolerance which can swing from + to -, or be in the middle. I make no assumptions and always measure.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Did you zero your digital calipers?
    I've never found a used shim more than .02mm off the printed size. New shims are almost always within .01mm.
    Your saying that you're getting .05 off. That's the next size. No way would BMW label the shims one full size off. The problem has to be with your caliper. Not reset to zero or bent.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Dum vivimus vivamus ted's Avatar
    When I did my valves recently mine were off that much, some more. That was, until the BMW tech who was guiding me along showed me how to properly zero out then how to properly measure with the $15 Harbor Freight digital caliper I had bought. Once I figured it out it was just as accurate as the $? Snap-On the Tech used. And as Lee mentioned, they were all pretty much spot on, maybe .01 variance - due perhapse more to the copious amounts of coffee I was drinking. I still measured each one at least twice before I put it in.
    PSA - you can still buy the blue tin (empty) that keeps them all segregated by size, unfortunately the blue tin packed with shims is NLA.
    Ted
    "A good stick is a good reason"
    1994 K75RT
    Moto Pages
    Jun 2009
    Rochester, MN
    Yes - 2 calipers - zero'd both - I guess that ONE shim is off??
    It's the only one of the lot that still has the printing. I was maybe thinking that 0.05 was recessed into somewhere - thanks for the info!
    Aug 2003
    Marion,Ar.
    I'm an old school machinist. I allways grab a micrometer, caliper, scale and double check my parts and thier dimensions.
    Aug 2003
    Marion,Ar.
    Precision measuring tools and device's
    These tools are used to measure accurately things like shims. 3 dial calipers, 1 digital caliper and 1 depth micrometer. I think the digital caliper is good to 0.0005 . The others are good to 0.001. There are more accurate vernier depth and standard micrometers that are accurate to 0.0001. They have another vernier on the barrel for this degree of mearure. All of these are over 20 years old.
    Aug 2003
    Marion,Ar.
    Depth micrometer
    Also showing the tool to adjust the micromter to 0.001. Set the tool on a special ground surface plate/ granite plate to set adjustment. I don't have access to either, so I use my precision angle plate or 1,2,3 block. Nice tool to use getting measurements in blind holes.
    Aug 2003
    Marion,Ar.
    Dial indicators
    Very accurate tools, used in many applications. Set up work on the bench, lathe, mills. Endless aplications in the machine shop, job shop, engine building, head work. Good tool.
    Aug 2003
    Marion,Ar.
    More Accurate Measureing Devices
    Scales, angle finder, small hole gauge, telescopic hole gauge, adjustable parallels. Used all these in machine shops, tool and die shops, and automotive machine shops.
    Aug 2003
    Marion,Ar.
    More gauges
    It's endless. Gauges for every thing. These are radius gauges. drill and wire gauge Radius finder
    Aug 2003
    Marion,Ar.
    Inside and outside calipers. Radius scribes Inside and outside calipers. Measuring devices. Primitive tools that are very useful in a machine shop
    Aug 2003
    Marion,Ar.
    Several micrometers. Also examples of standards. These are precise machined tools that are used to zero out your micrometers. A good set of micrometers will come with a standard for each size to zero out your mike's. 2 different types shown. Also shown are the wrenches that adust the micrometer to 0.000. The true name for micrometer is micrometer caliper, but I don't know anyone who uses that term.
    Aug 2003
    Marion,Ar.
    Yes measuring parts can be a little frustrating. When you have the proper tools and their properly calibated. Piece a cake.
    Apr 2006
    Nibley, UT USA
    But...but...where are the gage blocks to wring together, and the sine blocks? 😎
    Best,
    GTRider
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
