Results 1 to 15 of 22
Thread: Front lighting connector replacement/ repair needed 08RT
    Registered User dougalls's Avatar
    Jan 2014
    Courtice ON
    I have been trying to install new horns (found a pair of used R1150RT horns) and a Signal Dynamics headlight modulator recently. Screwed up and cut the hot leads too close to the connector...now I need a new one but cannot for the life of me find the part number or a replacement.
    Can anyone help?
    IMG_0231 by dougalls2007, on Flickr
    IMG_0229 by dougalls2007, on Flickr
    This is the plug that goes into the back of the nacelle (?) it has ground/ highbeam/ lowbeam/ lowbeam/ r signal/ l signal
    rabid reader dbrick's Avatar
    Santa Cruz CA
    I ran into a similar situation once and found that buried in the parts fiche are often several pages of connectors for this sort of repair. Take a look at this page from the fiche, particularly at the two panes titled "Repair Cable Main Cable Harness." There are a lot of connectors there; with some luck, the one you need will appear.
    David Brick
    Santa Cruz CA
    2007 R1200R, now gone
    Jan 2014
    Courtice ON
    Thanks Dave...saw that but no luck...part of my problem is I can't tell which numbers on the connector are the part numbers (i've tried searching for various assortments of the numbers on the connector) so I can't do what I thought would be the simple thing and simply look up then order the part. Maybe the dealer will know (that will be 567$ please...LOL).
    Registered User rocketmanli's Avatar
    Feb 2007
    Bay Shore, NY
    Most of these connectors are manufactured by either Tyco or AMP. I've had success with this company. Call them or shoot them a photo and see if they can locate it. I'm searching for pa66-gf30 but that might not be the entire part number.
    http://www.mouser.com/teampconnectors/
    If you can pull the top plug out with the cut wires and post a close up picture of both sides of it with all part numbers stamped, it will be much easier to find. The dealer will try to sell you the whole harness. Many times the connectors are available from electronic distributors, but not from the dealer. So don't look for a BMW part number, look for the AMP or Tyco number. Photos will help a lot. I found this out a few months ago when a couple of the black plastic H7 headlight bulb connectors cracked on my '09RT. I found the connectors for I think 40 cents a piece!
    Dec 2011
    Menlo Park, CA
    I don't know that connector, but most of the ones on the bike that I've seen are standard pin or blade-type that you should be able to release from the housing using the special tool developed for that purpose. If you do end up cutting the rest of the wires you could extract the connectors, patch in jumpers to the wiring harness, and reinsert the connectors. A good electronics store should be able to help you with that.
    Too bad about cutting the wires. Most of us can relate ...
    JayJay
    '09 R1200 RT, '73 R75/5 Toaster (under rehabilitation)
    Lots of rice burners in the past ...
    Jan 2014
    Courtice ON
    Thanks MOAs! I think the photo shows all the numbers...this is the plug from the $1500 harness that you have to unplug to remove the front nacelle which contains the headlights. The PA66-GF30 is actually the type of plastic...that's the only number that pops up anything when I input it. I will check NAPA today for an appropriate connector.
    Ya the mistake was mine for sure but the instructions from Signal Dynamics didn't make it clear that I was to cut the hot leads in "two"...I should have realized the lights didn't have power (the signals did though bec they weren't cut)...bah!
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    BMW sells them. You have to look at the fiche, but the connectors on the bike are sold individually as repair items.
    http://www.maxbmwmotorcycles.com/fic...0&rnd=04282014
    Look under Electrical System, scroll down and then you should see two items for Repair Cable Main Harness.
    We need a picture showing the pins side of the connector.
    My Motorrad Blog
    My Motorrad YouTube
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by dbrick View Post
    Sorry, I missed your post.
    My Motorrad Blog
    My Motorrad YouTube
    Feb 2007
    Bay Shore, NY
    Does the part with the PA66-GF30 unplug from the part labeled BMW 09 4016 01 61487 1? Or is it one contiguous piece? Hard to tell from the pics...Looks like a 6-pin plug, and I could only find 4 and smaller on the fiche. That's why I think you have to find the manufacturer of the plug itself. You know someone, somewhere built it, and you can be even more sure BMW won't tell you who. BTDT.
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by rocketmanli View Post
    There are 4 and 8 pin connectors...It would be nice to see the business end of the male and female connectors.
    My Motorrad Blog
    My Motorrad YouTube
    Feb 2007
    Bay Shore, NY
    One other option. A while ago I needed a special part for my '09 RT. Couldn't find it anywhere. Figured RT-P's use the same parts as RT's. I found Ian Smyth from R.I.G.S. Motorsports:
    http://rigsmotorsports.com/
    who sourced me an exact match for what I needed from a totaled R1200RT-P. His prices are great, quick delivery, and is an all around nice guy. Highly recommend him for parts. He bought a load of decommissioned RT-P's and if you shoot him a picture of your plug, he might be willing to cut the end off one of his harnesses and leave you enough length of wire to re-solder it on to yours.
    Jan 2014
    Courtice ON
    Headlights plug by dougalls2007, on Flickr
    That's the "male" part where the mangled female part plugs in.
    NAPA= no clue
    Cycle wrecker in town= no clue but has a 2000-2003 K12RS he can part out if its the same plug
    BMW dealer (Endras)= no clue will send to BMW canada
    Jan 2014
    Courtice ON
    BTW the female end seems to be one piece.
    2008 R1200RT, 2007 F650GS (sold), 1997 F650 Funduro (sold)
    Dec 2010
    Fountain Hills AZ
    These people would know where to get it as they have the plug in their headlight modulator: http://kisantech.com/mag/index.php/p.../p115w-a6.html
    Contact them. It's worth a try.
    My Motorrad Blog
    My Motorrad YouTube
    Jan 2014
    Courtice ON
    Thanks Ponch...I have messages in to BMW Canada, RIGs, this place http://whiteproducts.com, and I'll try your suggestion. Missed a week of near perfect riding weather here bec of my own ineptitude :-( oh well, I've had time for backrest, new horns, complete 100k service minus the final drive (guess that's my job today). Good thing it's a crappy calm warm and sunny Saturday here in the GTA...
