Results 1 to 9 of 9
Thread: RT throttle body sync
    Feb 2015
    Central Florida
    Cool RT throttle body sync
    I have a twin max, and was wondering if you need a GS-911 to synchronize the throttle bodies on a 2007 R 1200RT? I think the GS-911 locks the idle actuators in a certain position during synchronizing, but doesn't the idle actuators stop working at around 1500 rpm?
    i should be out riding! wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    not absolutely necessary but nice to have anyway...
    http://forums.bmwmoa.org/showthread....Sync-all-years
    ~wyman~
    2015 BMW S1000R - Duke - Black Storm Metallic
    2013 BMW R1200RT - Sassy - Fluid Grey Metallic
    Dec 2011
    Menlo Park, CA
    Quote Originally Posted by rongrosser View Post
    Ron - correct. GS911 is not necessary, but it's a great gizmo to have, if for no other reason than resetting the service reminder. And you should be balancing at a bit off idle (I do it at ~1800-2000, wherever I can get the bike to settle down) so you're not resting on the actuators.
    BTW - I've found my TwinMax to be exquisitely sensitive to the internal battery. I always start with a new one now.
    JayJay
    '09 R1200 RT, '73 R75/5 Toaster (under rehabilitation)
    Lots of rice burners in the past ...
    Registered User BernieEcht's Avatar
    Jacksonville, Fl
    Ron, I sync my 07 at around 3500-4000 rpm using a TwinMax. No GS-911 needed for that procedure.
    I do like to adjust my valves and change my air filter before hand.
    Your Idle is controlled by the computer is not adjustable.
    Bernie Echt
    2018 R1200RT-LC Alpenweiss, starting out fresh
    2007 R1200RT Double Silver sold (183702 Smiles), 2000 R11RT sold (103K)
    MOA#92589, BMWNEF, BMW-RA, AMA
    Kool Aid Dispenser! jimvonbaden's Avatar
    Mar 2004
    Alexandria, VA
    This will walk you through it without a GS911.
    http://www.jimvonbaden.com/R1200_TB_Sync.html
    Jim
    Feb 2015
    Central Florida
    Cool Valve adj & TB sync
    Thanks guys. I adjusted the valves and did the throttle body sync without the GS-911 and it came out pretty good. The bike I bought was dealer maintained up to the 24,000 mile service. I didn't quite get the bike as smooth as the dealer, but I came close. I did buy Jim's CD. A little more practice on adjusting the valves maybe. My 98 R1100R's valve adjustment seemed more complicated than the JVB method for the 07 RT. I'll just keep on ridin' and learnin'!
    Oct 2009
    Torrance CA
    I just did the throttle sync on R1200R for the first time at 30K miles. It was only off by 1.5 at full sensitivity, but it made a noticeable improvement in vibration at freeway speed. I was surprised.
    1988 K75 Low Seat
    2009 R1200R Roadster
    Quote Originally Posted by tinytrains View Post
    Sounds good if you can get it better then 1.5 on a TwinMax at full sensitivity. I assume you did a valve check beforehand? Chances are excellent you'll never need to touch the sync again.
    Oct 2009
    Torrance CA
    Yes. I just did a valve adjustment and the final reading varied about 0.5 from side to side. I was surprised a the reduction in vibration.
    1988 K75 Low Seat
