Results 1 to 9 of 9
Thread: '14 R1200GS Hand Numbing Vibration Throttle
    I've had this on several bikes over the years. Ride for a while you get that subtle vibration that causes numbing in your hands, (mostly throttle hand).
    While I used to buy heavier weighed bar ends on other bikes, the GS had the brush guards attached to the end of the bars and I'm not sure who may make them then to work with it.
    Are there other options even?
    2014 R1200GS------YAMAHA YZ-250R-----YAMAHA FJ-1100
    YAMAHA XT-350-----BMW K1200GT------YAMAHA FZR 1000
    SUZUKI RM-125-----BMW R1150GS------KAWASAKI ZX-10
    DUCATI 888 SPO-----HONDA XL-350------HONDA GOLD WING
    Sep 2006
    CENTEX USA
    A few things to help. A crampbuster / wrist rest allows you to loosen your grip and is a relatively low cost fix.
    Foam or neoprene grip covers help some. Padded gel gloves also in mix. A throttle lock like a Kaoko will work on a bike with handguards and allow you to lessen your need to grip as tight as well
    there is a item called a snake,but will not fit inside bars with end weight threaded plugs.
    On long days, I have to remind myself to ease up on the deathgrip. Someone posted a worn grip on a fairly new bike with nominal mileage and I had to wonder how darn tight that hand had to be to do that
    Found a RT thread...the bar weights might work on a GS
    http://forums.bmwmoa.org/showthread....ndlebar+weight
    Steve Henson-Mod Team and club tire changer
    Cowboyatheart
    Feb 2009
    Pender Harbour, B.C.
    Quote Originally Posted by dm930 View Post
    Cruise control
    Moringa, your body & brain will thank you! PM for discounts Smart Mix at TasteMoringa.com
    XM3 Energy, real energy for the body & brain, no sugar high, XM3.Energy
    One Ring To Rule Them All AirBender's Avatar
    Oct 2014
    Raleigh, NC
    Unhappy I know how the OP feels
    I'm on a '15 1200RT and I've hesitated about posting my own situation on this topic because I knew most everyone would say "loosen your grip" or "relax and enjoy the ride" or something to that extent. While I do agree w/ that theory, my situation is different as I have had a problem with my throttle hand numbing and "falling asleep' since I started riding motorcycles and have unfortunately experienced it on every bike I've ridden. Specifically it starts with my thumb and moves through my hand into my pointer finger. This happens most frequently at higher RPM's when the bike becomes more buzzy....especially above 5,000 rpm's. When in town or riding through the countryside where I can't use cruise control I am constantly having to take my hand off the throttle and drop my arm straight down to get blood back into my hand and alleviate the pain. For highway riding cruise control is the only saving grace for me...without it I don't think I could ride
    Lately I have focused on my grip pressure and seating position, but nothing seems to help. At this point I have given in to the fact that I just have poor circulation in my hands and the slight bar buzz exacerbates the problem
    I am going to try the foam or neoprene grip covers as henzilla recommended to see if that helps. Hopefully they won't affect the heated grips.
    "Are you living life the way you were meant to, or how you have been led to think you are supposed to?"
    1989 Yamaha FZR 400 Racebike (r.i.p.), 2009 Suzuki Hayabusa (sold), 1983 custom naked Honda Goldwing (sold), 2015 San Marino Blue BMW R1200RT
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    Quote Originally Posted by AirBender View Post
    Sounds like carpal tunnel problem: get checked out by an appropriate doctor.
    Harry
    My fleet: 2015 R1200GS, 2017 Toyota Prius Prime (plug-in hybrid)
    Sep 2006
    CENTEX USA
    On certain bikes it seems more pronounced to me. Maybe wrist angle also affects it.
    My RT was better after I installed risers, my GSA better when I flipped the stock risers 180 putting the bars forward.
    The covers do work with the heated grips, the neoprene heat transfer quicker
    As Harry points out...possible circulation issues. Aleve before a ride helps me. Repetive hammer use as well as impact tools for years did not help my grip issues.
    This issue is purely related to vibration of handlebars. It's obvious. Grabbing the bars more lightly relieves it a bit. Bar end weights would be great, but can't find any.
    I wonder if the position of the shoulders might also be an issue. Try twisting the bars up a bit and see if that helps for the shoulder positioning, and even the wrist position. I had to put risers on my bars. Then I started to notice my knees would ache after prolonged rides. I installed lowering pegs and it made a huge difference in that.
    The bottom line is that you should adjust the ergonomics to your bike first. If that isn't done, all kinds of pains will crop up.
    Oct 2011
    Florida & Massachusetts
    Do you think your bike has more vibration than it should? Since you've got dual O2 sensors you won't have a fuel imbalance at cruise. But if there is an air imbalance, there will be a power imbalance which would cause vibration.
