I dropped the oil out of the final drive. When I screwed back the drain plug to the drive shaft, it was stripped. I need to re-thread or helicoil. I got the final drive house off the swing by removing the shock absorber off, removing the adjusting nut off the brake, and the four nuts connecting the final drive to the swing arm. I took it to several machinist and was told I will have to disassemble the inside, i.e. final drive nut/washer/clutch hub, etc in order for him to bring pass the drill bit down so it will not damage the inside? Is this so AND is it difficult. I do have a service manual but it is questionable for me?
