Results 1 to 4 of 4
Thread: Seat Concepts Low Seat!
    Mar 2004
    Alexandria, VA
    Wanting just a bit more distance comfort on the new GSw I decided to try out the Seat Concepts Low Seat. The stock seat was not particularly tall, but SC tends to make them higher, so I went with the low seat. $169 is not a bad price, and if it doesn't work, I am confident I could trade it for a stocker and most of my cash.
    So, here is the original seat:
    Remove all the staples and the cover and foam. They are not glued on.
    The corners on front had removable plastic parts, I assume to keep the edges from being too sharp.
    Here you see the stock and SC foam differences.
    Installed with lots of 3/8" staples and a manual gun, and it looks pretty good, almost stock. The gap is the same as before.
    I sat on it and it feels OK, not really much shorter, and maybe a slight forward tilt compared to the very good stock seat!
    Tomorrow will tell.
    Jim
    www.JVBProductions.com Now, all videos available via download, Shifthead also now available.
    One Ring To Rule Them All AirBender's Avatar
    Oct 2014
    Raleigh, NC
    Nicely photographed post...looking forward to hearing the ride results.
    "Are you living life the way you were meant to, or how you have been led to think you are supposed to?"
    1989 Yamaha FZR 400 Racebike (r.i.p.), 2009 Suzuki Hayabusa (sold), 1983 custom naked Honda Goldwing (sold), 2015 San Marino Blue BMW R1200RT
    Mar 2004
    Alexandria, VA
    Thanks, not bad for a cell phone.
    I only got 20 miles today, but it felt pretty good. It was firm, with a dished out seat and no pressure on the jewels. Not much lower on reach to the ground due to a slightly wider profile and firm foam, so it should be good for some distance. Time will tell how far.
    Jim
    Massachusetts
    Nice write-up
    I had posed the seat concepts question a while back- http://forums.bmwmoa.org/showthread....oncepts-anyone as I am looking for some sort of upgrade for the TW-200 which cane with a 2X6 that gets harder with age.
    "You can do good or you can do well. Sooner or later they make you choose". MI5
    Moderator Team.
    2009 F800GS 1994 TW200
