Results 1 to 6 of 6
Thread: ATTENTION!!! All K bikes. HONDA MOLY 60 DISCONTINUED
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Honda Moly 60 (the go to lube for clutch and driveshaft splines) has been discontinued.
    It has been superceeded by Honda M77, but that is not the same animal. There is no listing on the tube or any listing of it that states the % of Moly content (although you might guess it to be 77%, but you might be wrong). The only application that I have found listed for it is for brake caliper assembly on Honda Civics. NOTHING about splines, nothing about motorcycles.
    The temp. rating for the M77 is 450 deg. The temp rating for Moly 60 is 750 deg. in a sliding application and 1500 deg. in a non sliding application. DEFINITELY NOT the same animal.
    The Honda forums have been abuzz for several months with people wondering what they are going to go to.
    The local Honda dealers knew nothing about it until I bought them out of Moly 60. The parts guys saw in there computers that it was NLA. When I asked their service depts. what they were going to use once their tube in the shop ran out, they didn't have a clue. So much for Honda Service Bulletins.
    You guys might want to check with your local Honda dealerships to see if they have a couple tubes left.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Apr 2015
    Southern Maine
    Moly 60 Alternative
    As an "old" Gold Wing driver it's interesting your using the Honda 60 Moly. I thought it was very pricey but used it whenever I pulled the wheel off for any maintenance on my previous bikes. Here is another alternative that looks like it has high temp range as well. Not cheap though!
    Loctite 51048
    Anti Seize Compound, Moly Paste, 8-Oz. Can
    Model: 51048 SKU: 283164
    Guard Dog Moly: GD525 Moly Grease
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Why not the GD570 with twice the Moly?
    (Paul, I figured this thread would be the best way to make users aware of the Guard Dog products)
    http://guarddogmoly.com/product-category/motorcycles/
    Mine, Hers, Spare
    I prefer the 525 to the 570 but I have both on the shelf. The 570 is is very much like the Honda stuff. I think it dries out too quickly, isn't as sticky and tenacious as the 525 and doesn't have as good cushioning characteristics as the 525. Ben Mathes at Guard Dog specifically formulated the 525 grease based on the requirements of BMW clutch splines. It winds up similar to the 50-50 mixture of Honda Moly 60 and Wurth Sig 3000 (sticky green grease) I used to mix up which wound up 30% moly by volume. That is what 525 is.
    Mansfield,MA
    No Mad Dog 20/20?
    Mod Squad
    2009 F800GS 1994 TW200
