Results 1 to 9 of 9
Thread: mounting and removing luggage
    Figuring out how to mount and remove the BMW panniers from my new 2012 R1200R, I discovered that I cannot remove the mounted one and cannot open the unmounted one with either of the keys. Is there a trick? This is too simple to be frustrated by, and yet…… Any suggestions?
    Mansfield,MA
    I don't know but have found going to a dealers site (like MAXBMW) and looking at the parts view frequently gives me a hint. On my F8 it's a double lock kinda deal.
    Mod Squad
    2009 F800GS 1994 TW200
    Good idea. I've talked with them but not looked at a parts diagram. …Annoying to have one off the other on!
    Retired from riding rad's Avatar
    Santa Cruz
    Yes, there is a trick. To open, turn the key to the open position then push down on the key. The wide flat release lever will pop up. To remove rotate the key firmly to the release position and the handle will pop part way up, lift it the rest of the way up and remove the luggage from the bike.
    Two assumptions made by me; you have stock factory luggage and 2012 luggage is the same as my 2007.
    Make that three assumptions, you have the proper key. If it goes in and turns it is the proper key.
    Thanks, Rad. Your assumptions are correct: BMW luggage, locks, and keys. I've followed the manual instructions, which are the same as your suggestions. One side worked a few times, now neither does, and I'm left with one bag on and the other off. It's a mystery, but evidently not a novel one as I've found that there are other owners with the same issue. I'm just hoping that the there's a 'trick' ––besides doing the right thing.
    Registered User waxrash's Avatar
    Jul 2011
    Garner, NC
    If you look at the bag that is off, you will see a plunger that protrudes from the box that locks it to the frame. Do it off bike a few time until you see what I am talking about. Now look under the mounted bag and find the same plunger. Is it jammed somehow. If the handle moves but that plunger does not, the bag is broken. You can separate the case, but be warned, it is an exercise to put back together, as parts will fall out and some head scratching will commence.
    The plunger protrudes and holds the bag against the frame with the weight supported by the two eyes at the top.
    I am assuming you have the same mechanism as my RT.
    Lynn
    2008 BMW R1200RT (most fun you can legally have)
    2002 BMW R1150RT
    2008 Kawasaki Versys
    Kool Aid Dispenser! jimvonbaden's Avatar
    Mar 2004
    Alexandria, VA
    Quote Originally Posted by waxrash View Post
    I had to replace both of my tabs when they broke in the accident. It wasn't too bad if you pay close attention when taking them apart.
    I didn't do a tutorial, these are photos from a rekey of them.
    Jim
    Jul 2011
    Garner, NC
    I broke one as well, but repaired it with epoxy putty. Seems to work fine.
    Lynn
    2002 BMW R1150RT
    Thanks !!
    Couldn’t get my handle to pop up. “Rotate the key FIRMLY ...” was very helpful. Thanks.
    Quote Originally Posted by rad View Post
