wvpc
Member
Need HELP! with the R side Throttle Bowden Cable.
I performed my 30K mile service without a hitch until attempting the Throttle Body Synch.
I touched only the right side cable. It seems as though the top adjuster no longer engages the threaded shaft that the bottom adjuster spins on. The top adjuster spins in either direction without engaging the threaded shaft.
How can I get the top adjuster to engage the threaded shaft? Is there anyone local who can help? I am in Ypsi, Michigan.
