Results 1 to 12 of 12
Thread: Front Wheel Removal
    ERIC1514
    Front Wheel Removal
    I'm taking the wheel off my K75c tomorrow morning so I can have a new tire installed. This is the first time I 've done this so please critique my method.
    1) Put bike on centerstand.
    2) Place scissor jack and piece of wood under oil pan.
    3) Raise jack and hopefully bike will rotate back onto rear wheel.
    4) Remove calipers, etc. This part I got covered with Clymers.
    5) Mark caliper on one side as to right or left and rotation with Magic Marker.
    Sound about right?
    TIA,
    Eric
    Focused kbasa's Avatar
    Yup, though a piece of blue tape will mark the rim pretty well too.
    Dave Swider
    Marin County, CA
    ERIC1514
    Thank you. I feel better.
    Take Care,
    Eric
    Don't forget your towel
    Bainbridge Island WA
    You're going to need to push to brake pistons back into the caliper bodies. I carefully use a long handled screwdriver to push 'em over. Try not to use the rotor too much as a leverage point or you stand a good chance of bending it.
    I also try to remember to suck a bit of brake fluid out of the MC and leave the cap loose to give the incoming fluid someplace to go.
    Steve
    ABC,AMA(LIFE),MOA,RA,IBMW MANICMECHANIC's Avatar
    May 2003
    Manitowoc, Wisconsin
    You'll do just fine. Just remember, after putting the wheel and calipers back on, PUMP UP THE BRAKES! Otherwise that first attempted stop will be memorable.
    F.O.G.Rider, Rounder #6,
    Ambassador, WI Airmarshal
    BMWRA Wisconsin Region Rep
    Eric
    After you jack up the front wheel to just clear the ground. Push back the brake pads, remove the calipers, pull the axle and you will have to jack up the front wheel some more to allow the wheel to clear the front fender and roll it out.
    Bruce C
    ERIC1514
    Morning,
    One more question. Do I need to bring the axle with me to the shop that is going to install the tire so that they can balance the wheel?
    Eric
    West Salem, OH
    Quote Originally Posted by Eric1514
    Morning,
    Eric
    Nope, they should have something there to use. If they are any kind of shop.
    Gale Smith
    2009 Versys
    1999 R1100RT
    Registered User breyfogle's Avatar
    Aug 2004
    Lomita (aka L.A.), SoCal
    I'm taking the wheel off my K75c ....
    Eric
    When you say "remove the calipers", I hope you mean only to unbolt the calipers from the fork tubes. The brake lines can be left intact with the calipers supported with wire ties to anything convenient. I don't see any reason to mark them right and left and there is no reason to push the pads back.
    '89 K75S Original Owner
    '94 (Beta) R11RS, ( RIP 12-5-2010 courtesy of blind left turning cage driver ) ....
    Quote Originally Posted by breyfogle
    Yeah, there's no reason to open the hydraulic system on the bike at all here. Just unbolt them with those two big bolts and slide them off the rotors and out of the way.
    Be sure to suspend the calipers with a coat hanger or bungee or something so the brake lines aren't under any kind of strain.
    Dave Swider
    Marin County, CA
    ERIC1514
    Done! Thanks to all for your replys. New tire looks nice.
    Eric
    P.S. Yeah, I unbolted the calipers from the forks and shoved a cedar wedge between the pads to both open them a tad and as a safeguard against accidentally grabbing the brake lever.
    CustomSarge
    Another consideration
    I pull my rotors when I change tires (I do'em myself), and you DO want to mark them to stay same side. I've found I can open the calipers a little by "rolling" them on the rotor towards the axle. G.H....<<<)))
