Results 1 to 15 of 27
Thread: 2014 RTW HID Headlight Installation
    Registered User 80092's Avatar
    Jan 2014
    Stroudsburg, Pa
    Here are 2 pictures of the HID Hi and Low beam finished installation. There are no lamp failure icons on the dash. Detailed report of installation to follow if interested.
    Peter Murray
    Stroudsburg, Pa.
    IBA 359
    2014 RTW, 73 R75/5
    Registered User azuwere's Avatar
    May 2011
    Gilbert, AZ
    Is that an after market kit or DIY?
    2014 R1200RT
    Albuquerque, NM
    No auto manufacturer anywhere has used HID for lights used as flashers, as HID burner warm-up time is too slow.
    Kent Christensen
    21482
    '12 R1200RT, '02 R1100S
    Jan 2014
    Stroudsburg, Pa
    Quote Originally Posted by azuwere View Post
    Both you could say . I used this kit with Phillips bulb's.
    http://www.kbcarstuff.com/Motorcycle...-Kits-s/34.htm
    Order the motorcycle kit for the Low beam ( 1 kit ) and the auto kit for the HI beam ( 2 HID kit's. ) . For the RTW you need to also order there Low beam failure fix for the low beam only.
    http://www.kbcarstuff.com/HID-Kit-Components-s/1501.htm
    Peter Murray
    Stroudsburg, Pa.
    IBA 359
    2014 RTW, 73 R75/5
    Jan 2014
    Stroudsburg, Pa
    Kent I'M not sure what you are implying, the subject matter is for the Headlight not Blinkers ?
    Peter Murray
    Stroudsburg, Pa.
    IBA 359
    2014 RTW, 73 R75/5
    Mar 2004
    Alexandria, VA
    Quote Originally Posted by 80092 View Post
    He means high beams when used as a flash to pass mode.
    Personally I have done it on 2 R1200GS Hexheads and Camheads. The initial HID flash is pretty bright, enough to use as a flash to pass IMHO, though some disagree.
    He is right that it is not done by any OEM though. With LEDs these days I am betting it never will as LED will take over for HID in mass market soon enough.
    Jim
    PS I am definitely interested in a photo tutorial of the HID conversion process. I have it for the GS, but not the RT.
    www.JVBProductions.com Now, all videos available via download, Shifthead also now available.
    Quote Originally Posted by jimvonbaden View Post
    Jim
    +1
    me too
    d'milan
    Mansfield,MA
    Always interested in a good DIY. If you need help, let me know.
    Mod Squad
    2009 F800GS 1994 TW200
    Jan 2014
    Stroudsburg, Pa
    Jim
    I thought he may have been referring to the Autobon flash to pass . Yes the HID Hi beam will flash well when cold. I will put together a photo tutorial hopefully some time this weekend. LEDs do require a little warm up as well although much quicker than HID..
    Peter Murray
    Stroudsburg, Pa.
    IBA 359
    2014 RTW, 73 R75/5
    Dec 2014
    Winnipeg, Canada
    Headlight Upgrade
    I kept it simple by changing the bulbs with Osram H1 Night Breaker Unlimited with a color temp. of 3700 deg. K And Sylvania Silverstar Ultra for the low / high beam. A modest investment and a noticeable improvement in light output and color. White with only a hint of blue. The Osram bulbs re shape the light pattern putting more light in the ditch. It helps, I do a bit of night riding in Deer country, the beam is further out there as advertised and I do not piss off on coming traffic as does my buddy with his LED driving lamps. I have LED's on my '83 RT and I do know how these miss shaped light patterns affect on comers.
    I do think LED's will be the future but they have to be properly focused to put the light where it should be. I just want to smash the Harley LED head light but my brother in law won't let me, they are on his bike. That's OK though, he can't keep up anyways. I have had issues with HID ballasts in my wife's car as it ages so I see them gone as soon as LED's work properly. Nice light but expensive to maintain / fix.
    I am mounting Motolights with halogen bulbs to the new RT, I had them on an F800ST and now I have a brake caliper mount to add them on to the RTW. More on that when the snow is gone.
    Brian Mansky
    1983 R100RT, 2014 R1200RT, the old RT will be an RS soon.
    Jan 2014
    Stroudsburg, Pa
    Detailed Installation
    Here is my detailed installation of the RTW H-7 Low and H-1Hi beam installation . I sourced my HID products through KB car stuff , very high quality. I went with the Phillips Xtreme HID kit a@ 4300 Kelvin ,the 4300 K is true white light .
    Order the motorcycle kit for 1 low beam H-7 and the Automotive lighting package for 2 Hi beam H-1 systems. You will also need KBs Low Beam Failure Fix .
    Without the RFIX the low beam turns off when switching to Hi beam and will not reignite due to a low beam fault. The fault is due to a reduction in power to the low beam when the Hi beam is switched on. Thus the Low beam requires a relay supplied in the kit.
    Order od disassembly to do the job. Remove the following 13 items and in this order . Front Seat , Front Fender , R Battery Cover , Wind Screen , L & R Engine Spoiler , L & R Side Panel , L & R Knee Cover , L & R Speaker Cover , L & R Speaker , Cover for windshield adjuster , L Inside panel , L Storage compartment , Insturement Panel with bracket .
    Front seat
    Remove Battery cover R , no pic.
    Peter Murray
    Stroudsburg, Pa.
    IBA 359
    2014 RTW, 73 R75/5
    Jan 2014
    Stroudsburg, Pa
    Peter Murray
    Stroudsburg, Pa.
    IBA 359
    2014 RTW, 73 R75/5
    Jan 2014
    Stroudsburg, Pa
    Peter Murray
    Stroudsburg, Pa.
    IBA 359
    2014 RTW, 73 R75/5
    Jan 2014
    Stroudsburg, Pa
    4 Continued
    Last part to remove is the Horn , unbolt and leave wires connected.
    Now the fun begins , the most difficult part is installing the bulbs. I started with the Low beam in the center. The bulb cover is removed with a slight CCW turn .The cover must be drilled to allow the HID bulb and + and - kit connectors to pass into the light housing. I used a step bit to drill a round hole 1.15 " large .Now pass through the HID bulb and blue and black kit wires into the cover, secure the gromet to the bulb cover .
    Next disconnect the wires I used a pair of long needle nose pliers . Remove the low beam bulb note it's orientation , be very careful when unhooking the wire bale.
    Insert the HID bulb , be sure to seat bulb properly , if not the focus will be off. Now time to hook up the HID and RFIX connections.
    Peter Murray
    Stroudsburg, Pa.
    IBA 359
    2014 RTW, 73 R75/5
    Jan 2014
    Stroudsburg, Pa
    5 continued
    BMW deviates the traditional wiring for lighting on the RTW . The 2 female plug connectors for the Low beam have a single black lead and a 2 wire black lead. WTH The single wire is + , plug the kit blue wire here, and the other wire goes to the double wire for ground. Stuff the wires into the light housing and install the cover. I do not have a picture of the LB cover installed due to lack of room for picture, it will look similar to the HI beam cover you will see.
    Next we have to find a place for the Ballast , Igniter, RFIX , Relay and connectors . The Ballast was placed on top of the Headlight housing under the windshield motor and behind the dash. I used double sided tape supplied with the kit. Clean the housing with alcohol before applying tape. The Igniter and relay were zip tied to the ballast . Here is a picture of the dash with some kit wiring ( Ballast , Igniter , Relay not seen but under thus wiring sorry.
    Peter Murray
    Stroudsburg, Pa.
    IBA 359
    2014 RTW, 73 R75/5
