Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 49
Thread: '13 R1200RT starting issue
  1. #16
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    The K75/100/1100/1200 bikes had the sight glass and filler on the same side.
    The R1100/1150 bikes had the sight glass and filler on the same side.
    The earliest R1200 bikes had the sight glass and filler on the same side.
    Then along came the engineering intern who switched things up.
  2. #17
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Careful... that former intern is now the Chief of the Department of Redundant, Extraneous and Vexing Innovations Department at BMW Motorrad.
    Kevin Huddy
    Silver City, Montana
    MOA# 24,790 Ambassador
  3. #18
    Dec 2004
    Winnebago, Il
    And he is doing an outstanding job
    Roy G.
    85 K100RT Ol Ruby "Gone but not forgotten"
    02 K1200LTC Hoss "Wrecked on 9/21/14"
    12 R1200RT
  4. #19
    Dec 2011
    Menlo Park, CA
    I don't think it was an intern. I think the same engineer who designed the headlight bulb retaining system in the R12RTs decided to switch from bodywork to mechanical.
    JayJay
    '09 R1200 RT, '73 R75/5 Toaster (under rehabilitation)
    Lots of rice burners in the past ...
  5. #20
    Angry
    Well, the RT started once using the OM procedure, but the temp dropped and it has not started since. Hauled to dealer for the 3rd time and they wheeled it into the service bay and put it on a charger. When they got to it a couple of days later, the bike started right up (as I would expect, since the service bay is about 60 degrees). They blamed my battery tender because it is a 3 amp charger, but it automatically drops to maintenance level when the battery is charged. I tried to demonstrate the problem when we unloaded the bike off the wrecker, but the dealer just said the tech would look at it later. My concern now is that cold weather is past, they have not diagnosed the issue, and it will not manifest itself until January '16, at which time we will be back to square one. I do not believe the battery is the problem, even if they do replace it. I have been riding BMWs for 15 years without a major problem, so I don't fault either Motorrad or the dealer, but they need to address the problem and convince me I do not have a lemon.
  6. #21
    2013 Staring Issues
    I also have an 2013 R1200RT that we just purchased three weeks ago with only 480 miles on the OD. It was a BMW Regional Manaager's Demo, Esentially a new bike. I put about 200 miles on it the first weekend with not problems starting or otherwise. Memorial day weekend we took a four day weekend and rode a 1200 mile loop from Denver up to the Bad Lands of SD, over to Devils Tower and back home. We left early Friday morning, it was cool and raining (45 degrees) I noticed that the bike started a bit hard, i.e., had to crank it a bit before if fired up. I didn't think much of it. We stopped a couple of times on the way up to the Bad Lands, weather remained cool and rainy. Don't remember restarting being and issue. The next morning when we were ready to get underway the bike started very hard. Really had to let it crank and work the throttle to get it fired up. It was probably about 40 degrees... I was starting to get concerned. We previously had a 2000 RT that we had ridden in temps down to 27 degrees and never had this kind of issue. But wait it gets better. The next morning, cool, 45 degrees, same hard start issue. Finally on the way back home Monday, we stopped for fuel and lunch. When we were getting ready to leave, the bike would not start. I cranked until the bike started click, click click. i.e., I thought the battery was tapped out. Called road service thinking that I at least needed a jump. Contacting road service took about 30 minutes or so. While waiting for service I thought, I'll try starting the bike one more time, hit the starter and varoom... The bike fired right up... Go figure. We rode home parked the bike in the heated garage and let it set until yesterday morning when I was going to take it into the dealer to get it checked out... No Start... No Start and all... Ran it down to click, click, click... Let it set on trickle charger for a couple of hours, tried to start it again, no joy.. Temps in the mid 60's... Called road service and had it hauled to to the dealer... Service manager suspects fuel pump or clogged jets. I suspect a sensor failing... Any thoughts out there from the community????
  7. #22
    2011 Starting
    On a recent trip from KY to CA I noticed a difference in starting from normal. In the mornings parked outside, not in the normal garage, the bike was harder to start. (37-45 degrees). On several occasions I had to apply throttle while starting. I also thought that this may be due to the higher altitudes which were 6-7000 feet in the morning. During the day at higher altitudes the bike started right up without throttle. Bike never failed though.
    'I'm funky now in every way".
    2011 R1200RT
    2015 Ducati Multistrada
    2013 Honda CRF250L
  8. #23
    Nov 2011
    Central Ohio
    All the 2005-2013 R1200 manuals include a phrase like this:
    For cold starts and at low
    ambient temperatures: pull the
    lever to disengage the clutch
    and twist the throttle grip
    slightly."
    From experience, it seems that BMW considers 40-45F to be the threshold for low ambient temperatures. Below that range, the battery will die before the engine starts on a closed throttle. Above that I've not needed to touch the throttle, even for the first "cold" start of the day.
    Larry
    2006 R1200RT
  9. #24
    Quote Originally Posted by lkraus View Post
    slightly."
    Thanks for that info I missed in the manual. My bike is behaving as normal.
    2011 R1200RT
    2013 Honda CRF250L
  10. #25
    Shop Says It's Fixed....
    Follow-up on my post of a few days ago,
    I also have an 2013 R1200RT that we just purchased three weeks ago with only 480 miles on the OD. It was a BMW Regional Manager's Demo, Essentially a new bike. I put about 200 miles on it the first weekend with not problems starting or otherwise. Memorial day weekend we took a four day weekend and rode a 1200 mile loop from Denver up to the Bad Lands of SD, over to Devils Tower and back home. We left early Friday morning, it was cool and raining (45 degrees) I noticed that the bike started a bit hard, i.e., had to crank it a bit before if fired up. I didn't think much of it. We stopped a couple of times on the way up to the Bad Lands, weather remained cool and rainy. Don't remember restarting being and issue. The next morning when we were ready to get underway the bike started very hard. Really had to let it crank and work the throttle to get it fired up. It was probably about 40 degrees... I was starting to get concerned. We previously had a 2000 RT that we had ridden in temps down to 27 degrees and never had this kind of issue. But wait it gets better. The next morning, cool, 45 degrees, same hard start issue. Finally on the way back home Monday, we stopped for fuel and lunch. When we were getting ready to leave, the bike would not start. I cranked until the bike started click, click click. i.e., I thought the battery was tapped out. Called road service thinking that I at least needed a jump. Contacting road service took about 30 minutes or so. While waiting for service I thought, I'll try starting the bike one more time, hit the starter and varoom... The bike fired right up... Go figure. We rode home parked the bike in the heated garage and let it set until yesterday morning when I was going to take it into the dealer to get it checked out... No Start... No Start and all... Ran it down to click, click, click... Let it set on trickle charger for a couple of hours, tried to start it again, no joy.. Temps in the mid 60's... Called road service and had it hauled to the dealer... Service manager suspects fuel pump or clogged jets. I suspect a sensor failing... Any thoughts out there from the community????
    Got a call from the shop this morning, Service Manager says it was a bad fuel pump??? BMW replaced the pump under warrantee, he says I'm good to go. I am still puzzled as to why once I got the bike started it ran with no problems if it had a bad fuel pump? I'm not a mechanic and don't even play one on TV, but it seems to me that I would have noticed some performance issues if the fuel pump was not functioning properly. Does this seen strange to anyone else?
    Service Manger told me that they have this problem with a lot of new bikes that have just been setting around and not really run that much. He said we will sell a bike that's been setting on the floor for a few months and the fuel pump or jetting gets clogged up. Has anyone else heard this and does it seem rational?
    2013 R1200RT
    2011 KLR 650
    2006 400 drz
  11. #26
    Nov 2005
    Fairfax, VA
    Certainly possible. If the pump gets gummed up, it may not start to rotate when electricity is initially applied. Later (like after conditions change, such as cooling) the pump's resistance to turning may be lower, and once turning will keep turning.
    Just one guess; point is it really could have been the pump.
    Mark Neblett
    Fairfax, VA
    #32806
  12. #27
    Runs Like a Scared Rabbit
    Picked up my bike from the shop yesterday. I am now convinced it was the fuel pump. When I first picked up the bike and for the approximately 1500 miles that I put on it, I thought the bike a bit sluggish. I had to really rev it up when starting from a stop. With the new fuel pump the thing runs like a scared rabbit. It's a completely different bike.
    I originally thought this was a cold weather starting issue, but not so..
    Maybe some here who think they are having cold weather issues may actually be having a fuel delivery issue related to the fuel pump...
    2013 R1200RT
    2011 KLR 650
    2006 400 drz
  13. #28
    Registered User Hodadd's Avatar
    Apr 2014
    Central Coast, CA
    Interesting. I recently took my '13 RT on a long trip throughout the western US. When stopped overnight in Colorado I barely got the bike started in the morning. Cracking the throttle didn't work. I only got it going when I twisted the throttle open to more than 1/4 to 1/2 open. Then once running I had to keep the revs up until it was warm. Only then would it idle. I don't know if it was temperature, altitude, or both combined to cause the issue. I do know that my bike horrible as the elevations climbed higher.
    Quis custodiet ipsos custodes? - Juvenal
    (Who watches the watchers)
  14. #29
    That Was How My 13RT Behaved
    That was exactly how mine behaved and I live here in Colorado... I think in my case it was the fuel pump, but I still think there could be other reasons such as a misbehaving sensor, clogged fuel filter or jets. We are getting ready to do a tour of the State in a couple of weeks. Hopefully that should be enough to see if we have totally fixed the problem.
    2013 R1200RT
    2011 KLR 650
    2006 400 drz
  15. #30
    Apr 2014
    Central Coast, CA
    With mine, on the way home I rode into the dealer and complained about it. It was also pinging horribly at any elevation above about 4k feet or so. Long story short, the dealer said several valves were out of adjustment and several of the spark plugs had defective electrodes. I bought my bike last year as a left over and it was due for the 12k service, so they just chalked it up to that. I'm not totally convinced, but it is running better. However, I started noticing the running issues at elevations and around the 10,500 mile mark. I had performed the 6k myself and I do know that several of the valves were tight, but within specs, so hopefully this was a one of a kind deal. Otherwise I can not tolerate a bike that when in need of routine servicing runs horribly.
    This is my 5th beemer and none of the others did this, so I guess I'll see.
