Results 1 to 9 of 9
Thread: Basecamp for Garmin
    Basecamp for Garmin
    So I downloaded this program but it does not have any streets. Do I have to buy the North America map in order to make routes in the US?
    Live it, or live with it
    Dec 2005
    AZ, USA
    Sort of. Connect your Garmin GPS, jump through some registration hoops IIRC, and the maps will be transferred to Basecamp.
    Motor On '/,
    Registered User c4golf's Avatar
    Jan 2014
    Phoenix,AZ
    Plus go into advanced settings and click the box to download to the computer as well. So you can plan without having the Nav connected.
    Tim C
    2016 K1600GTL
    Matte Ocean Blue
    Yeah, what everyone said. The Basecamp program is just sort of a shell. The maps themselves are linked to your unit. If you don't have a unit with maps on them or a map subscription, you can buy them separately. I ended up buying them for the version of Basecamp on the laptop that travel with even though the unit itself installed them on my desktop. And do remember as just stated, for some inexplicable reason when you update maps, the default setting is to install them only on the GPS device instead of the device and the computer. But if you have different versions on your GPS and computer, it can cause problems when you design and upload routes.
    On my cpmputer the advanced tab doesn't light up, stays grey.
    Buck in Greensboro, NC
    2013 R 1200 RT Midnight Blue - traded, 2014 R 1200 RT Ebony Metallic, 2016 S 1000 XR
    Just to clarify.
    1) plug the GPS into the computer and let the computer see it
    2) Run Garmin Express
    3) Select install or reinstall maps
    4) In the install or reinstall maps box, click "advanced options"
    5) From the pull down menu, select "device and computer" or "computer only"
    Mansfield,MA
    Good info guys
    Added this thread to The Best of GPS- http://forums.bmwmoa.org/showthread....he-Best-of-GPS
    Mod Squad
    2009 F800GS 1994 TW200
    Aug 2013
    Florida Space coast
    OSM maps
    I created a free map of the U.S. at an OSM site. I don't use a Garmin unit. The chart is navigable just as the garmin maps, has the same level of detail and can be used in the very same way, at least as far as I can see. I use my iPad mini and now iPhone 6+ for my guidance.
    Aug 2013
    Florida Space coast
    OSM maps
    http://garmin.openstreetmap.nl
