Results 1 to 4 of 4
Thread: How do you delete an ad in the Marketplace ?
    13278
    Apr 2006
    Near Lynchburg, VA
    I want to delete an ad and am having a difficult time. I'm sure it must be simple the second time, maybe.
    13278
    MOA Life Member t2moyer's Avatar
    Sep 2004
    Birmingham, AL
    You can delete or cancel a listing. After you login, under the Marketplace Tools tab will be a choice for Your Listings. When you click that, you should get a list of everything and on the right side will be two options - edit or cancel. You can also click into any listing and there will be a green title bar across the top with the same two options.
    Ted Moyer
    '12 DL650, '06 R1200RT, '78 R100RS Motosport, '72 XL250, '83 RZ350, '94 KLX650, '80 GS850G
    13278
    Apr 2006
    Near Lynchburg, VA
    I cancelled the ad from "Your Listings" and all it did was add " No Longer Available " to the title. It's fine with me, but I was sort of expecting removal of the add. I looked in "Flea Market" and it seems to be gone from there, but I'm not sure why there is a Marketplace and a Flea Market. Never saw a green bar. I've tried to save someone from wasting their time. I'm certainly not going to waste any more of my time, even though it s probably operator error. Done.
    Charlie
    Liaison 20774's Avatar
    I read in the ON there was a bit of user instruction on the new marketplace. It can be found here after you scroll down the page a bit:
    http://www.bmwmoa.org/?page=marketplace
