Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 73
Thread: Broken Throttle Body Pulleys 2009 R1200RT
  1. #31
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by bruud View Post
    When the throttle body pulleys broke I was rolling on full throttle and had just shifted into 3rd gear as I was merging into traffic coming up on me from the rear at probably 80 mph. I was merging onto a two-lane highway with heavy traffic and no acceleration lane and when the motor went to an idle I took the only escape route available - the suicide lane separating opposing lanes of traffic. Obviously the plastic pulleys could not take the stress of hard, full-on throttle, something I needed to keep from getting run over from the rear. The dealer told me they rarely see this breakage, except on police bikes, where it is surmised that motor officers stress the pulleys with full-on hard acceleration, as in a pursuit endeavor. Regardless, in my opinion, this is a design and manufacturing flaw that could cost one his life, and that is exactly what a motor officer told me whose service bike was a 1200RT of the same vintage. This flaw demands a recall and retrofit with a metal pulley that, in my opinion, should be designed and offered by BMW Motorad. This flaw, uncorrected, will one day lead to a lawsuit because the flaw is documented.
    Bart
    I had been stopped at a light and was shifting between first and second when it happened. Like you, I wondered who was behind me?I put in a complaint too and even exchanged emails with BMWNA, but their solution was for me to have the dealer install new TBs and send them the receipt for review. I ended up getting used parts.
    How many miles were on your bike? My bike had 29843 miles on it when it happened. How much did the dealer charge? How much did Bing Charge? Just wondering. My guess is the dealer bill would be at least $1400. There's not enough BMW kool-aid or wacky weed to make me want to pay that much, let alone it's a defect, for plastic pulleys.
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
  2. #32
    Re TB pulleys
    My RT had 48,832 miles when the pulleys broke. The dealer quote was $1,304 but I negotiated that downward a few dollars. Can't find the receipt but it was over $1,200.
    Since the repair I am careful to avoid rolling on the throttle to the hilt.
    BING was good to me. No charge. I had a lengthy email conversation with them over a matter of weeks and as much as anything, perhaps they wanted to see the broken pulleys because they stood their ground with their belief that their design and manufacturing process was solid. I was elated that they worked with me on this matter.
    In my opinion, the pulleys and pulley shafts should be available in the aftermarket. Together they should be a relatively inexpensive item. It is insane to have to install new throttle bodies because of a flaw that could easily be corrected. A steel pulley swaged onto the shaft would be an easy retrofit. With retrofitting it would be important to balance the left and right TB functions.
  3. #33
    Dec 2010
    Fountain Hills AZ
    I found a set on eBay, with all the hardware still attached, meaning cables and FI with lower mileage than my bike. I paid $265 with shipping installed them myself.
    I wonder if Bing would want to look at mine?
    My Motorrad
  4. #34
    Mansfield,MA
    Quote Originally Posted by ponch1 View Post
    While no doubt a PITA.... on getting through this and advising the members.
    Mod Squad
    2009 F800GS 1994 TW200
  5. #35
    Spring Lake NJ, USA
    In my quest to invoke Eilenberger's Law of Spares (You never need the part you have..) - back when my bike was almost new I spotted a set on Ebay - $100 for the pair, with cables and injectors/hoses/steppers. Haven't needed them and hope not to. It's worth keeping an eye on Ebay for items like this - sometimes it's worth just having them, if you never need them, you won't have a problem selling them when you're done with the bike.
  6. #36
    Dec 2010
    Fountain Hills AZ
    I got Eilenberger's second axiom when dealing with BMW over this or at least a modified version:
    "And I'm sure based on BMW's usual reactions to these sort of things:
    1. What problem?
    2. Oh, that problem. First we've heard of it.
    3. You caused it
    4. Your environment caused it (fuel properties usually)
    5. We have no problem"
    My Motorrad
  7. #37
    Registered User ratze's Avatar
    Feb 2013
    US, EAST TNN.
    OK folks, i am sporting a new to me 09gs and i could be wrong but my guess is, it has the same setup. iam going down to have a look, having said that, had i known. there are other manufactures out there. i scooped this bike up with the hopes of not turning a wrench for at liest one season. i do like the bike, the electrical system is virtually maintenance free. i sapose they had to leave something, BUT. safety is a huge issue with me,,,,,
    The pursuit of reality at all cost.
  8. #38
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by ratze View Post
    Including myself, I have only found 4 instances of this being reported, three of which have put in a complaint to the NHTSA. That said, I think it's a very rare problem, but troubling if you've had it happen. The 2009 is the last year of the hexhead and if there have been any common bugs, they've been worked out and it won't have the switch gear problems of the later bikes, so it's not a bad purchase. Just make sure there are some sort of service records kept on the bike so you know how it's been taken care of. Also, you didn't say how many miles are on it, which would give us some info of what to look for in terms of what it might need, if anything. Also, just as a curiosity, what bikes have you owned before this? I find it interesting on how people end up on BMWs. It's such a strange bike to me as I've had some minor issues, but I can't stay mad at it long. It's like a temperamental wife that is talented. What can I say.
    My Motorrad
  9. #39
    Feb 2013
    US, EAST TNN.
    I went down and had a look, same setup. iam not going to worry about it as i never twist the grip full on anyway. the bike has 39 on the clock, ive got the tank off er now. valve adj, canister. horn, lites and the famous AFXied and several other upgrades. i think the bike will do exactly what i need it to do, ive been on 02 1150 for many sweet miles, not a nut nerbolt on that bike that has"ent been fussed with. a quater million miles, what iam really gona miss with the gs is weather protection. the rt was the best for that, anyone know if clutch has a diff design than rt, ive had that gearbox ota ther 3 times. once jes because, when we head out for a 3 month trip the last thing i wana be thinking about is spine issues when in coldfoot alaska. sorry, splines. my gs has full aftermarket exhaust system with electronic wilbers sus, runs way to lean for my liking though, its in the process of coming around to my way of thinking. been on 2 wheels for 45yrs. 35yrs of that was on moto guzzis, 1970 ambasador. 74 eldorado of which i still have, would that be considered vintage. yes i am getting to old to be turning the spanner. honestly though,wrenching on em is 75% of the ride for me. iam an ole gear head and cant even help it. i guess thers worse things ta be addicted to. ride on,,,
  10. #40
    Dec 2010
    Fountain Hills AZ
    The 1200's don't have input shaft spline issues as the earlier bike do. That was fixed I suppose. If you've had a 1150, then the maintenance is very familiar. The one thing about the GS that is better is the lack of tupperware as it's easier to work on.
    My Motorrad
  11. #41
    Feb 2013
    US, EAST TNN.
    The RT tupperwear was great for slicing through the windy western states, dono how the gs is gona be. iam gona find out as soon as the weather breaks. deadhorse ak again.
  12. #42
    Dec 2010
    Fountain Hills AZ
    I contacted Bing and they referred me to the Bing Agency. Oh well.
    My Motorrad
  13. #43
    OK. Bing Agency (in Kansas) is the North American distributor for Bing. So I would contact them by telephone and tell them you need new shafts with pulleys and that Bing said you should contact them.
    Back in the early days of the R1100 and worn throttle body shafts the parts were not available through BMW. But with sufficient requests Bing Agency got them into their parts inventory.
  14. #44
    Dec 2010
    Fountain Hills AZ
    I was hoping they'd want to see the TBs themselves, like the other gentleman I quoted. I guess I could send an email.
    My Motorrad
  15. #45
    Oct 2007
    Redmond, WA
    Using the zoom feature on eBay to look at throttle body pictures shows a lot of them have visible cracks in the plastic pulleys!
