Page 1 of 5 1 2 3 ... LastLast
Results 1 to 15 of 71
Thread: Broken Throttle Body Pulleys 2009 R1200RT
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Has anyone every seen this happen? Mine broke on Wednesday. I was shifting to second and the RPMs dropped to idle. I had to get a tow and after I got everything off, I eventually discovered the pulleys/cams on the throttle bodies were broken off. They are plastic, which is incredible. Is the bike made by Mattel? Steel has always worked...
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    I think this very issue has been discussed a couple of times on the threads. I'm curious if the '05's were steel, as I don't here much about their failure.
    R. Reece Mullins Ebony R1200RT (Gretchen)
    MOA # 143779
    MOA Charter Club #5 #364 #100
    BMW MOA Vice President
    Dec 2010
    Fountain Hills AZ
    BMW NA suggested I have it fixed at a dealer. Whatever. I know what's wrong with it and new parts and labor would probably cost $1400ish. May be a little more. Using plastic is ridiculous.
    My Motorrad
    Dec 2010
    Fountain Hills AZ
    Seems I am not the first nor the only one: http://www.arfc.org/complaints/2009/.../10609639.aspx
    I filed a complaint too.
    My Motorrad
    So what was the verdict? You gonna order the part and replace it yourself. Does BMW offer a non-plastic throttle body pulley?
    MOA # 143779
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by rangerreece View Post
    I found a set of throttle bodies on ebay with the cables/cable distributor box/fuel injection. The pulleys cannot be replaced by themselves. THe whole throttle body has to be replaced.
    My Motorrad
    Dec 2010
    Fountain Hills AZ
    Just the throttle bodies from BMW are $536 each.
    My Motorrad
    Still plays with trains. tinytrains's Avatar
    Oct 2009
    Torrance CA
    The pulley on each throttle body broke simultaneously?
    That is just bizarre.
    2009 R1200R Roadster
    Registered User liv2ride's Avatar
    May 2012
    Honolulu, HI
    Quote Originally Posted by ponch1 View Post
    Good for you Ponch.
    Hopefully BMW NA will step up to fix this significant safety issue. There is hope, especially since they recently started replacing left and right switch gear on the 2010 and up models, even those not experiencing a failure. I don't believe, the switches were nearly the level of concern as this piece.
    Hope you get back on the road soon.
    Aloha
    Dec 2010
    Fountain Hills AZ
    Well, I was contacted by BMW NA. I was pleasantly surprised, but I not expectant. We'll see.
    My Motorrad
    Nov 2007
    There is no such thing as bad plastic. There is a lot of incorrect application of plastic. The interface of plastic over metal is a hard one to do correctly.
    I can not believe the weight savings was significant.
    Rod
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by ragtoplvr View Post
    Rod
    Not sure what you mean by plastic over metal, but the pulley is separate from the metal parts and doesn't have metal within it. That said, I was jesting when I said save weight. May be sarcastic is a better word.
    My Motorrad
    Unless I am lost somewhere the pulley is plastic; the shaft is metal.
    I think this is a golden opportunity for a bright engineer / entrepeneur with a 3-D printer.
    May 2012
    Honolulu, HI
    It would be great if an engineer amongst us would assist to develop a retrofit using a more appropriate material. I am sure anyone in Ponch's situation would gladly compensate the individual should they need help.
    Dec 2010
    Fountain Hills AZ
    Eggzackery.
    My Motorrad
