dieselyoda
Active member
Last summer, slow speed, about 20mph, I curbed my front wheel on a man-hole cover flange. It was a good thump and my bike definitely noticed and complained. I stopped, checked all the usual stuff, tire for gouges, rim being bent and steering all OK. Seemed OK. The next ride, higher speeds, some twists and turns, the steering felt heavy as in needing to hold counter steer more than before. This was really noticeable at acceleration on an apex.
I've been through the front end a few times now and I think there isn't a real problem except the bike doesn't seem to handle as well as it should. I followed the old rule, complaints in the front are almost always from the rear. Everything seems fine in the rear, smooth, nothing loose. The front seems fine as well.
I would think that if I had a steering head bearing dented and starting to spall, I would feel it but I can't. My next thought takes me to the ball-joint. It is just a semi-spherical bearing and if I dented that, I should feel it, I would think. My thought is that the ball joint is unloaded when on the center stand and therefore, feels good. I wonder what it's like loaded.
I will replace the steering head bearings and the front wheel bearings because that sounds like a reasonable and relatively inexpensive and the ball joint isn't that much money but before I open my wallet, is there a way to check the ball-joint?
