Hi all,
I have two different brands of a plastic graduated fill bottle very similar to the one I've seen referenced in various maintenance tutorials. (They can be found at beauty supply stores, and I think BeemerBoneYard sells one.) I'd say they are pretty much the same when comparing the graduated markings. I then compared their measured volume with a Pyrex measuring cup, and found that the difference was about 10ml. If the Pyrex measuring cup is correct, then 180ml of oil measured using these plastic bottles would really be 190ml.
Now, I wouldn't normally get too worked up about 10ml (or even 20ml), but considering BMW thought it important enough to reduce the fill amount, I'm thinking it's kind of important to to get this right.
Has anyone else checked the graduated markings on these fill bottles for accuracy? I'm thinking of taking one into my local dealership and seeing if they will compare it to whatever they use to measure out the final drive oil.
--Jason
--Jason
