Results 1 to 15 of 17
Thread: Mag Wheels vs. Spoke Wheels
    What are your thoughts on mag wheels vs. spoke wheels ? I ride 80% on the road, will do some fire roads, not likely to cross Utah or Colorado off road. Can Mag Wheels handle moderate off road duty ?
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Yes. The F700GS comes with cast wheels. They're just fine for fire roads.
    Added advantage over the F800GS wire wheels is that they are tubeless, so you can plug flats instead of having to break down the wheel to patch the tube.
    But I wouldn't want to take it TOO far off road in rough terrain where you run a greater risk of bending the rim. You want a cast rim with as many spokes as possible (8 or more). Forget the three spokes (they bend on the street).
    What model bike?
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    2015 GS
    Decisions decisions
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Mine, Hers, Spare
    Opinion: spoke look nicer, cast are easier to clean. I had cast wheels on my '05 GS, got spoke with my '13. I had no issues with cast on dirt and gravel roads.
    Mar 2011
    socal
    Spoke wheels on a 1200GS are tubeless
    If I had a choice of spoked or cast wheels on a 1200 I would go with the spoked, just in case they can take a far greater impact than the cast ones and they look better
    wanderer
    Jun 2009
    Bridport Vermont
    It is a trade off
    Spoke wheels look sexier to most people. They are "tougher" than cast. But not necessarily stronger. Tough as in taking big hits, deflecting, bending to absorb the hit and springing back to position ..hopefully. Usually spoke wheels cost a lot more, take more effort to clean. BMW spoke wheels now are tubeless....good for easier puncture repair....but with out tube...one can not really pressure them down a lot for better traction in dirt, sand, gravel. A benefit of tube type dirt tires . So now tire performance is the same on spoke and cast wheels.
    Cast wheels are stiffer, hold up to sideload with less deflection so do better handling the twisties on pavement. The are considerably lighter...so have less unspung weight...better suspension performance. Cast wheels, contrary to common believe are not very brittle. For safety reason BMW and most others use a relatively malleable alloy so the wheel( ususallty rim) bends on big hits. This some time causes a flat tire and out of round wheel.
    As I only do pavement and dirt roads....no real off road. Cast wheels are better for me.
    Albuquerque, NM
    Surprised you feel cast wheels are lighter than spoke wheels.
    Kent Christensen
    21482
    Nov 2011
    Central Ohio
    Weight, in pounds, from the MAXBMW parts fiche, R1200GSW
    Code:
    	Front	Rear
    Wire	13.62	11.97
    Cast	14.11	10.1
    Differences are small enough that I'd not use weight as a deciding factor.
    Larry
    2006 R1200RT
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by lkraus View Post
    Code:
    	Front	Rear
    Wire	13.62	11.97
    Cast	14.11	10.1
    I see different weights on the MAX site for the GSW.
    Front wire is 14.11 lbs and the front cast is 11.77 lbs.
    MAX shows the set of wire wheels weighs 4.21 lbs more than cast wheels.
    I don't know if the weights on the parts fiche or accurate, or if they are just shipping weights.
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User Moto316's Avatar
    Nov 2007
    Phoenix, AZ
    Quote Originally Posted by Bradkap View Post
    Yes, the mag wheels can handle moderate off road duty. I ride an 07 1200GS and have not had any problems with the mag wheels that came with the bike. I drop the pressure to about 25psi when riding a lot of dirt roads, the tires hook up better and no issues with the rims.
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    Ask your parts man (or the MAX BMW parts fiche) what the replacement cost is for each type of wheel. That probably ought to factor in to a decision.
    Harry
    My fleet: 2015 R1200GS, 2017 Toyota Prius Prime (plug-in hybrid)
    May 2003
    SW Iowa
    Quote Originally Posted by AKsuited View Post
    Harry
    Ouch, a set of spoke wheels cost $725 more than cast.
    Lee
    2016 R1200RS
    MOA # 30878
    Albuquerque, NM
    Assembled by hand.
    Kent Christensen
    21482
    atlanta
    On a 20k+ bike it is not a big deal.
    Marty Hill
    7 GS white
    Ride till you can't
