Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 61 to 75 of 92
Thread: Forum Operations
  1. #61
    Registered User cehlbeck's Avatar
    Apr 2011
    Acworth, GA
    Angry Log in but then it says I'm a guest?
    I'm an MOA and a forum user. The past 2 days to use the forum is getting frustrating.
    I log in (I never bother with the remember me or staying logged in). I get the "flash screen" thanking me for logging in and then the forum screen. But it says I'm a guest and have limited options. This goes on over several attempts and I give up. Then suddenly it lets me again.
    Chris Ehlbeck
    BMWMOA 168990
    Chris & Donna's Motorcycle Journeys
  2. #62
    Certifiable Old Fart beemerdons's Avatar
    Mar 2006
    Chandler, AZ
    Didn't help.
    Brother Lee, same here! Damn frustrating!
    Don Stanley; aka Chuy Medina "El Burrito Ballerina"
    BMWMOA #24810; www.azbeemers.org/forum #89
  3. #63
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    I have no desire to organize a lynch mob nor do I think one is needed.
    I just participated in a test for Ted that appears to have my Chrome problems solved for now. Thank you. I will admit my long term confidence is low given we are 11 days into this if my counting is correct.
    Assuming this does resolve; then it is time for the powers to be to debrief those who have worked on this project, identify successes and pit falls, then develop and release a benchmark policy/procedure/guideline, to the forum membership, explaining the baseline for doing upgrades in the future.
    Me, Myself, I and The Other Guy Inside the Helmet will be holding an executive meeting with the Right Hip that holds the "the power of the purse". Lacking that or something that meets those kinds of informational needs I can tell you the personal BoD is leaning toward not making the various money and time expenditures to participate. The BMW MOA BoD and Exc Dir can do the opportunity cost benefit analysis for the group.
    There is a light at the end of this tunnel. According to the map there are more tunnels ahead. Without knowing how we are going to navigate the road ahead off roading is looking more and more like a viable option.
  4. #64
    Back in the saddle again mikegalbicka's Avatar
    Aug 2014
    Lakeland,FL
    Is that the .ORG or .COM forum?
    .COM
    http://www.vbulletin.com/forum/search?searchJSON={%22keywords%22%3A%224.2.2+upgra de+problem%22%2C%22channel%22%3A[%2255%22]%2C%22sort%22%3A{%22relevance%22%3A%22desc%22}%2C% 22view%22%3A%22%22%2C%22exclude_type%22%3A[%22vBForum_PrivateMessage%22]}&btnSubmit=&humanverify[input]=&humanverify[hash]=&humanverify[input]=&humanverify[hash]=
    As I said it was just a quick review and I was just trying to point out other problems that others were having. Not being a vBulletin admin I really can't speak to which version is the most stable but I do agree that you should never be an early adopter which is the same as a beta tester sometimes unless you want to help debug products. Also most IT pro's will agree it is very important to properly test upgrades in a test environment before roll out to ensure user satisfaction after go live date.
    Note: it seems when the link above is saved it inserts a space in "upgrade" which must be removed to work.
  5. #65
    Mansfield,MA
    It shouldn't have been 11 days, for me it was 2. I know many run multiple browsers, I have DOS
    Mika, if you think the help you received would help others- please share. I do understand that in some circumstances this is not possible.
    Mod Squad
    2009 F800GS 1994 TW200
  6. #66
    Debbie's Servant Lee's Avatar
    SW Iowa
    Ted has me fixed up on my work computer. I'll check my home computer tonight. If it works here it should work at home.
    Thanks Ted
    Lee
    2016 R1200RS
    MOA # 30878
  7. #67
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Quote Originally Posted by t2moyer View Post
    Personally, I don't believe this has been managed improperly given the constraints that we face.
    It is those constraints that I want to have mitigated. You and your team may have done as well as could be expected, but that does not mean it has been done well enough. It comes down to where one sets the standard. In this case the standard has been set by several other forums and we are not meeting that standard. I again want to make it clear that I am not attacking, blaming or disparaging you. You are in the arena, I am a spectator. I'll not criticize you for not slaying the lions fast enough because you've been given only a slingshot to work with. I just want you to be given a bigger weapon.
    Kevin Huddy
    Never have more ambition than adhesion.
  8. #68
    Feb 2009
    Mississauga, Ontario
    As of November 18-9th I am no longer "remembered" and have to log in every time. Up to this point there was no problem. Just to let you know.
    Walter
    "Every decent man is ashamed of the government he lives under."
    H. L. Mencken
  9. #69
    MOA Life Member t2moyer's Avatar
    Sep 2004
    Birmingham, AL
    Fingers Crossed
    I think I have the issue identified. If you are not able to login or having difficulty with being remembered, email me and I can reset your password to the forum administratively. This will make your forum password and main site password different, but once you have logged into the forum, I can match the two.
    This is a workaround for the moment. The authentication script is not storing the cookies on your local machine depending on how the authentication with the main member database occurs. The solution for the moment is for me to set your password to the forum and then match it in the member database. This is only an issue for some people and browsers depending on their history and cookie handling on their machine.
    Bottom line, if you are having difficulty, email me or call me and I can reset your access and likely get you in and remembered.
    Ted Moyer
    '12 DL650, '06 R1200RT, '78 R100RS Motosport, '72 XL250, '83 RZ350, '94 KLX650, '80 GS850G
  10. #70
    Sep 2004
    Birmingham, AL
    Quote Originally Posted by akbeemer View Post
    A bigger weapon is cool, but the standard by which you are measuring is not an applicable standard. Those "other" sites aren't doing what we are doing. Operating the same isn't a reality when you add in all the complexity that goes along with our forum. If you want to talk about a stand alone forum that doesn't authenticate against our members, the story is different.
    I can build a separate vB forum with it's own database of users that doesn't interact with the membership database and it can work flawlessly, just like ADVrider or fjrforums. Or, I can use our standard forum product that comes packaged with our membership software, but it isn't as rich as vB. Those things are perfectly capable and manageable to your expectations. Putting the two together is the difficulty and likely uses more of our resources than anyone is willing to give.
    I can build a really cool custom chopper. I can build a motorcycle that handles really well. Building really cool custom chopper than handles really well might be impossible. Don't take this as being argumentative, but an affirmation that people are thinking about these issues and trying to come up with solutions that will satisfy all the requirements. I just isn't as easy as it would appear on the surface.
    Ted Moyer
  11. #71
    Mansfield,MA
    Quote Originally Posted by cehlbeck View Post
    Chances are if you can get to the place that I have been describing (where the cookie files are) you will see BMWMOA listed at least twice. If you can get those cleared, I think you will be in better shape.
    A number of Members haven't changed their bookmarks for the forum which should really be done as well.
    Mod Squad
  12. #72
    Aug 2014
    Lakeland,FL
    It just isn't as easy as it would appear on the surface.
    Which is why it needs to be done by professionals who have the training, experience and knowledge to get it done on time and on budget with the least amount of problems.
  13. #73
    Aug 2014
    Lakeland,FL
    This workaround seems to have solved my problem but only time will tell for sure. Thanks for your efforts Ted.
    From all appearances this is a server side problem and no amount of tweaking on the client (user) side will fix it so don't bother clearing anything until Ted does the reset for you and you test it that way.
    Here's hoping they get the server side authentication fixed so this workaround does not remain the fix too far in the future.
  14. #74
    Fenwick, Ontario Canada
    I also have to log in every time.
    Now it won't let me post anything for sale?
    Ambassador Emeritus BMW MOA Ontario Canada
    Niagara Riders
    Knights of the Roundel #333
    1977 R100RS, (Retired) 1993 R100GS
  15. #75
    Aug 2014
    Lakeland,FL
    Quote Originally Posted by Darryl Cainey View Post
    per Ted "If you are having problems logging in, call or email me directly. ted@bmwmoa.org, 205-821-7205. I'll be glad to help you."
