Results 1 to 15 of 16
Thread: Fender reflector holes
    NYrider
    Jun 2006
    Manhattan
    "14 RT. I didn't get a reflector. And these rear fender holes are begging for one. Or a decorative farkle, e.g. logo/s
    Any ideas?
    NYrider
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User jeff.jakusz's Avatar
    Jul 2014
    Twin Cities, Minnesota
    Quote Originally Posted by KyleTurner View Post
    Any ideas?
    I found this solution for my bike. I ordered the bracket from the gentleman in the link and the roundel from eBay. After a little futzing pulling these parts together it turned out to be a great solution for filling holes!
    http://www.k1600forum.com/forum/bmw-...ar-fender.html
    2015 R1200RT - Callisto Grey
    May 2003
    SW Iowa
    Quote Originally Posted by jeff.jakusz View Post
    Looks good
    How is the roundel fastened to the bracket?
    Lee
    2016 R1200RS
    MOA # 30878
    Jul 2014
    Looks good
    The roundel (standard BMW part 51-14-8164-924) is adhesive backed and has two pins that are used for alignment. The bracket has the pin holes that not only allow for perfect alignment but also it is a snug fit which aids in keeping it in place.
    Albuquerque, NM
    I bet those are rear fog light mount holes.
    Kent Christensen
    21482
    May 2003
    SW Iowa
    Holes for large European plates
    Lee
    2016 R1200RS
    MOA # 30878
    NYrider
    Jun 2006
    Manhattan
    Thanks for the suggestions. I'm leaning toward auxiliary brake lighting. Something like what Lee suggested. Or perhaps Hyper lights, if they'll go in that place. Any Hyperlite insight/pics would be appreciated.
    NYrider
    My hyper lights went on either side of the license plate frame.
    Buck in Greensboro, NC
    2013 R 1200 RT Midnight Blue - traded, 2014 R 1200 RT Ebony Metallic, 2016 S 1000 XR
    Registered User KarlG's Avatar
    Jun 2014
    Central NY
    Add a BMW LED brake light.
    The BMW CANBUS supplemental LED brake light is NOT compatible with the WC GS and RT per Max BMW website.
    Installation requires separate purchase of adapter harness for specific year and model BMW. Not all models are supported. Note: this light is not compatible with K5X new boxer models: R1200GS/GSA W, R1200RT.
    https://www.maxbmwmotorcycles.com/fi...am=LI_LEDADDON
    Registered User dogsbody's Avatar
    Oct 2006
    The Other Washington
    Regarding the roundel/bracket, is drilling required to mount that bracket to the fender? I bought one and don't see how to get the nuts provided with the bracket behind the screw holes molded in the fender.
    Jul 2014
    Quote Originally Posted by dogsbody View Post
    The fender is adjustable. Looking at the fender from the inside there is one nut to remove and the entire adjustable portion of the fender can be removed. That will allow you to mount the bracket without drilling. Once complete, reinstall the adjustable fender part which will slide right back on.
    May 2003
    SW Iowa
    Does it help to slide the fender extension down when mounting the bracket?
    Lee
    2016 R1200RS
    MOA # 30878
    Oct 2006
    Thanks for the information. Very fast replies!
    1997 Green R850R Mr. Toad
    2014 R1200RT no name yet but this bike is a wonder.
    May 2003
    SW Iowa
    I was not fast enough
    Lee
    2016 R1200RS
    MOA # 30878
