Results 1 to 15 of 18
Thread: Scheduled Maintenance For Paralever Pivot? '03 R1100S
    Left Coast Rider
    Nov 2011
    After doing the 9 - 3 o'clock (and the 12 - 6 o'clock) wiggle check mine seem fine, and I don't see any reference to this in the owner's manual, but is there a certain mileage at which the pivot bearings should be re-torqued/greased/renewed?
    Thanks!
    Nov 2007
    Quote Originally Posted by BC1100S View Post
    Thanks!
    IMHO you should not re torque the bearings after they have been in service more than a few thousand miles. This is because the races brinell (dented) or corrode from the insufficient moisture seal. If you retorque the bearing will likely lock up on the dents or corrosion, and start sliding on the pivot pins. If your pivot pins are not well locktited they can then work loose. You will be replacing pivot pins along with the bearings, more $$ for a limited amount of miles. I pack all the extra silicone grease I can get in the bearing, trying to eliminate all air spaces. Then I pack more grease around the ends of the bearing before assembly. For me this has worked much better, my current set has 40K miles, longest so far, and they are still tight.
    Rod
    Out of 20 or so sets I have had the occasion to open and examine only one was not damaged to the point I wouldn't reuse. Most of these did not show any play when the wheel/tire was wiggled. It is now my assumption that the bearings will need to be replaced any time I remove a final drive.
    Left Coast Rider
    Nov 2011
    So gentlemen, with nearly 50k miles on the original pivot bearings, am I on borrowed time? I'd hate to get part way through next year and have to replace them. Could make a good winter project. And thanks for the input!
    Apr 2005
    Walland, TN
    Paul,
    Do you still have a good impression of the durability of the JL bushings when properly greased and lubricated?
    Dave
    2004 R 1150 GS
    Quote Originally Posted by PETDOC View Post
    Paul,
    Dave
    Yes. I have not had problems with ours at all.
    Apr 2005
    Walland, TN
    Thanks. I meant to say properly greased and torqued.
    2004 R 1150 GS
    Registered User SeabeckS's Avatar
    Oct 2005
    GPS (Greater Puget Sound)
    Or...you could just purchase my Pencil Lead Gray/School Bus Yellow '04 that only has 19,874 miles (31,984km in Canadian terms) and rid yourself of those pesky worn out pivot bearings!
    Of course, in the bargain you'd be getting a MUCH faster S bike!
    Cheers!
    PS. My membership is about to expire, so be quick with any witty rejoinders!
    Bill Johnston
    Jammess jammess's Avatar
    Aug 2005
    Florence, OR.
    Or, you could make me an offer that i just can't refuse on my one owner pristine '04RT WITH 46K miles that just had its pivot bearings checked, lubed, and re-torqued to 11 Nm then re-assembled without loctite. Hey, I even phased the drive shaft. My sub runs out in December so no hurry on the witty responses.
    Jammess
    '93 R1100RSL, '10 FJR1300A
    MOA # 50714
    Left Coast Rider
    Nov 2011
    1. Both SeabeckS and Jammess need to renew their memberships. I will accept no excuse for not doing so.
    2. While your Pencil Lead Grey / School Bus Yellow "S" may be faster, I'd have to wear a paper bag over my head before and after riding it.
    Aug 2005
    Florence, OR.
    In reference to #1: That would be a no thanks on the membership renewal.
    Jammess
    MOA # 50714
    Oct 2005
    FREE paper bags included in sale price, get yours now!
    Bill Johnston
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by SeabeckS View Post
    Geez, you make it hard to pass up a deal like this!
    Oct 2005
    Yeah, we Scots drive a hard bargain.
    Bill Johnston
    Aug 2005
    Florence, OR.
    Duuuhhhh...free paper bags??
    Jammess
    MOA # 50714
